Samsung lns4095dx Lines/ Distortion
  • wacka
    • Apr 2014
    So I have green horizontal scan lines or white vertical scan lines depending on the aspect ratio and resolution of the TV.
    The distortion changes with the aspect ratio, the smaller the aspect ratio the less distortion.
    The distortion changes with the resolution, 1080p is much worse then 720p.
    At 720p
    At 1080p
    The lines are NOT over the menus and do not effect parts of the screen when there is no picture on screen such as no signal or in 4x3 ratio.
    So far I have:
    Swapped the mainboard
    Changed the capacitors on the power board except for the two with the rubber cover
    Swapped the tcon
    Re seated all the cables
    Any help would be appreciated. Thanks
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Samsung lns4095dx Lines/ Distortion
    It appears the issue is located centrally in the middle mostly. Have you ever got the screen wet ex. Windex?
    • wacka
      • Apr 2014
      No I haven't, it started slowly and got worse over the course of a few months. In person it really is more off to the left side in full or just scan aspect in 16:9 is more towards the middle even though its hard to tell from the photos. Its a moving pattern like interference.
      16:9
      Just Scan
        Since it changes with display resolution it's almost certainly a main board fault.
        • wacka
          • Apr 2014
          I switched the main board and it was the exact same thing with same pattern. I have also changed the capacitors on the power board and changed the tcon. Is it possible to get another board to cause the same issue?, the shop I ordered it from claims it was tested.
            09-07-2024, 05:50 AM
          • Rubenlily
            Samsung QE50Q67TAU - horizontal lines
            by Rubenlily
            First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
            I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
            I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
            I'm no expert but I've done the tape...
            08-16-2023, 01:12 PM
          • jeyoung12
            Samsung QN50Q60t lines on screen
            by jeyoung12
            Hi all
            I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
            My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
            This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
            It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
            So....i don't know what end of the C ribbon to work with...
            02-26-2024, 10:38 AM
            09-06-2024, 11:40 PM
