Samsung LE32B450C4W smoking ccfl xfrm
  • notallbad
    • Oct 2012
    • 1190
    Samsung
    LE32B450C4WXXU
    Power / Inverter board : BN44-00261B
    TV received with a dark band across the top, picture fine - backlight issue.
    Tested ccfl xfrm and replaced after finding differences between the 2 on the board.
    Replaced transformer QGAH02094 NY0903FB with QGAH02094 0 11TM49 A.
    Had it on for an hour and had a burning smell, thought it was burning off lacquer from the new xfrm, but now when turning tv on it smokes and almost immediately after turning on.
    Could just be a dodgy xfrm, ebay seller immediately refunded, no questions or fuss, did advise could be fault on board causing this.
    Anyone had any experience with these xfms?
    On inspection found the HV output side burning/smoking and the resistance is way high,
  • notallbad
    • Oct 2012
    • 1190
    Re: Samsung LE32B450C4W smoking ccfl xfrm
    Photos to follow along with a few quick tests.
    • notallbad
      • Oct 2012
      • 1190
      So driving the top ccfl lamps with the 'good' xfrm, moved psu/inverter board up so the bottom xfrn is connected to the top lamps, the lamps come on briefly, 2 secs to black obviously as the other xfrm is not connected to anything, no flickering like is does with the 'bad' xfmr and no smoking/burning.
      I think this test is good enough to eliminate the lamps/wiring.
      As a note, when connecting the 'bad' xfmr to the bottom lamps the xfmr still smokes/burns.
        That would be a reasonable elimination.
        How about a picture of the power board?
        Maybe the transformers are different parts? Check schematic, if available, to be sure.
        Are they driven from the same power electronics (transistors, etc) and is it a 24V inverter or high voltage (primary side powered, danger of electric shock etc.)
        • notallbad
          • Oct 2012
          • 1190
          Photos
          • notallbad
            • Oct 2012
            • 1190
            On COLD side of xfrm QGAH02092 SW , so must be driven by 24v.
              It appears to use a transformer to drive the transformers. TI9015. That creates the pri-sec isolation. Not a 24V design though.
              • notallbad
                • Oct 2012
                • 1190
                Isn't that TI801S?
                  Yes... probably... hard to read in your photo
                    I ran into two of these setups and the lamps were bad, it has blackened ends (you can see red glow at the ends inside the lamps) and draw lots of current even though the lamps still light up. I would inspect the lamps real well also.
                    • Shinju
                      • Mar 2014
                      • 1239
                      Also these boards are known for bad soldier joints on the aluminum rails so I would check for that too.
                      I have repaired several of this style of PS/INV 4 to 3 to 2 transformer types. All of them have had at least 1 loose connection.
                      • Alastair E
                        Chief Womble
                        • Mar 2013
                        • 1963
                        • U.K.
                        Looks like a dry-joint on that Tx leg caused a burn-up.....
                        TELEFIX
                        • notallbad
                          • Oct 2012
                          • 1190
                          Thanks for the replies.
                          Was hoping not to have to tear down the bl panel but may have to just to be sure there are no bad lamps as suggested.
                          I believe the solder joint to have been made good as were the others though possible I may not have made a good enough job on that joint and caused the issue.
                            09-07-2024, 05:50 AM
                            09-06-2024, 11:40 PM
                            09-06-2024, 08:40 PM
                            Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook Specification for Upgrade or Repair
                            This specification for the Samsung Galaxy Book Ion NP950XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-K01DE boardview and NP950XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                            09-06-2024, 06:20 PM
