LG 50PS60-UA Top half black sometimes, whole screen black sometimes
  • DJRCB
    • 22
    Hey guys!
    I'm just looking for some help to trouble shoot my LG (50PS60-UA)plasma screen issues. I've done a little bit of reading/research and found out this is a pretty common issue, and there are a few possible culprits
    the issues are intermittent but change very frequently
    ISSUES:
    1-Sometimes the top half of the screen is black
    2-Sometimes the top half of the screen has black and red lines covering it
    3- Sometimes the top half of the screen is compeltly fine
    4- Sometimes the Whole screen is black
    usually there will be a combination of the first 3 symptoms for about 5 mins then eventually symptom 4 always happens and stays that way until the tv is turned off and on
    i did Va/Vs voltage test they are both within the specs listed on the board.
    so, my question is.. where do i start? how do i begin to narrow down the issue(s)
    Ive included some pics to help with the process
    thanks for any help! i really appreciate it
  • freakaftr8
    • Oct 2012
    • 3743
    Re: LG 50PS60-UA Top half black sometimes, whole screen black sometimes
    Im going to start by saying faulty connection going from Y sustain to upper buffer board. Remove buff er r boards from y sustain and reconnect to start.
      Someone on here had an LG 50PS3000 (same generation, nearly identical parts) with this symptom, it was a bad ribbon cable from the control board to the Y-sustain.
      • manstoblame
        • Jan 2011
        • 85
        I'm in agreement with tom66 usually its a ribbon problem and simply loosening the ribbon holder and tapping with your fingers will sometimes make it apparent which one is faulty more than likely it needs re-seated or replaced I have 4 ribbons going from my t-con two control left side of set and two the other side definitely the ribbons
        • DJRCB
          • 22
          I took a look at the connectors and cables on the Y sus board couldnt see any visible signs of damage or anything. i took the board off, disconnected it from the buffer boards and control board. looked for cold joints. couldnt see anything. reconnected it, problem still exists
          anything else i can try?
          cheers
          • DJRCB
            • 22
            So I've pulled it off again and re connected everything still same issue.
            can anyone tell me where to start troubleshooting so i can narrow down if its a buffer board, ribbon cables or Ysus board
            cheers
              Maybe worth taking a house hold hairdryer and heating parts up as it seems to be a thermal issue. If the fault occurs when something is heated it should be investigated.
              • DJRCB
                • 22
                on the buffer board or the y sus board?
                thanks again
                  Yes, and try the control board too...
                  • DJRCB
                    • 22
                    I just re read your post. I don't know if I would consider it a thermal issue. The problem is constant from a cold start. So its not a matter of issue arising after x amount of time of being on.
                    The screen is never fully working for any longer than 20 secs or so.
                    Hope this clears up the problem I'm having?
                    Cheers
                    • DJRCB
                      • 22
                      Just to clarify my problem..
                      When I turn my TV on, the screen is completely black (I get sound). I turn it off and on, after the 3rd or 4th time turning it on/off the bottom half of the screen will come on but the top half will either by completely black or will half red and back lines running completely across the top half (sometimes the top half will work perfectly for a few secs) but mostly its black or has lines across it. Eventually after about a minute or two the whole screen goes black again.
                      Cheers
                      • DJRCB
                        • 22
                        BUMP
                        • Raulnn
                          TD Systems K50DLG12US half black and half white screen
                          by Raulnn
                          good night! I have this screen that looks half black and half white. the tcon gives a low vgh value (5-6v). the rest seem fine. I first removed the flex from one half of the panel and then the other. Removing the left, vgh increases it to 25-26v. I think the problem is in that area, but there are not many elements on the integrated controller board. there are no shorted capacitors. could they be a cof? Some help?
                          By the way, now the entire screen is black. Maybe some flex was not connected correctly... I have exchanged the flex and there are no variations, I don't think they are the...
                          01-20-2024, 04:49 PM
                        • Demonith
                          Adler-43ae99s Plz help me fix it ! half black screen
                          by Demonith
                          Hi i am not expert on fixing i am learning just to make shore about but every help is welcome so i have here Adler-43ae99s and what i done is replace the bad capacitors on mainboard and backlights now what i have problem is its all black no image no sound so i have try testing it on RCON flat cables when i remove LEFT its black and white but when i remove RIGHT its all black now i am on dead end here and i am feel let down on my self with this one i hope some one will help
                          02-10-2025, 12:12 PM
                        • kca
                          by kca
                          Hello all ~
                          08-31-2025, 06:38 AM
                        • ktmmotocross
                          asus FX506LI display goes half black when charger is attached and when laptop start or in bios. on battery in windows work ok
                          by ktmmotocross
                          Have this weird problem with asus FX506LI thats display goes half black when charger is attached and from start untill u pout charger in and pull it out. then display like switch to other mode and works ok.
                          I try to shut sown nvidia gpu but it is still the same. there is no bios menu to power down nvidia card. it taped display so i want my options before i pull it out
                          Asus FX506LI-HN227T
                          SN-M4NRCX0S90516C...
                          01-02-2024, 11:23 AM
                          HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                          This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                          09-12-2024, 02:00 PM
