Led24970dvdfh
  • sordids999
    • May 2013
    • 2152
    Led24970dvdfh
    hello guys
    got this tv today it turns on fine but then the screen just flashes Green,Yellow,Red,Blue etc etc
    any ideas
    ill post pictures later
    update : sorry its a BUSH
    Re: Led24970dvdfh
    What are the boards inside the set? Vestel, or another OEM?
    • sordids999
      • May 2013
      • 2152
      Re: Led24970dvdfh
      Hmmm exactly the same parts i fixed the other day with the shorted diodes
      Vestel 17IPS61-2 Psu
      17MB62-2.6 Mainboard
      i tried this but i cant get into service mode:
      To turn off the burn-in mode, please follow these instructions:
      1. Press the "M" button on the remote to obtain the on-screen menu.
      2. Press the numbers 4 7 2 5 in quick succession to enter service mode.
      3. Highlight Option 1 using the Down arrow on your remote control.
      4. Once highlighted, press the Right arrow to access Option 1.
      5. Highlight Burn-in Mode using the Down arrow on your remote control.
      6. Now press the Right arrow to turn off Burn-in mode.
      7. When Burn-in mode is set to No, press OK on the remote control to exit the service mode.
        Re: Led24970dvdfh
        They're everywhere, these Vestel junkers.
        I was about to suggest something along those lines. Second suggestion is to try updating the firmware.
        If you have a similar set, you can copy the firmware off it:
        https://www.badcaps.net/forum/showpo...92&postcount=8
        This will then allow you to install the firmware on the new TV.
        Please upload the firmware you copy off, if you do, as it will help others.
        There's no dedicated EEPROM on these sets you could try resetting unfortunately.
        • sordids999
          • May 2013
          • 2152
          Re: Led24970dvdfh
          The only other sets i have are the 19 inch and 22 inch JMB tvs with the same parts but i dont think the firmware would be the same ?
          i can get into the menu when i turn the tv on but 20 secs later the screen colours start changing and you can not access the menu any more
            Re: Led24970dvdfh
            Do you have any access to 4-7-2-5 MENU or MENU 4-7-2-5?
            The other sets: May work IF -- they both have same panel (Samsung = Samsung, LG = LG, etc.), they are both 1080p and they both have DVD players.
            • sordids999
              • May 2013
              • 2152
              Re: Led24970dvdfh
              no firstly the JMB are not dvd players so that wont work and i tried 4-7-2-5 MENU or MENU 4-7-2-5 but you only have roughly 10-15 secs before the screen flashes so what we looking at maybe only option replacement mainboard ?
                Re: Led24970dvdfh
                Unfortunately that may be the only option, 10-15 seconds though. if you're fast, I reckon you could reach the reset option. Do you feel lucky? Well, do ya, punk?
                You could also try NVRAM download on THIS set, then re-install firmware from the download, that might reset the software. It is worth a shot if you're going to buy a new board - can't break it any further.
                I seem to recall a Samsung that had this issue on this forum and the guy tried for 1/2 hour before he managed to get it. (Would shut off 10 seconds after power on.) Practice makes perfect......
                • sordids999
                  • May 2013
                  • 2152
                  Re: Led24970dvdfh
                  Punk
                  ok ill try it now
                  • sordids999
                    • May 2013
                    • 2152
                    Re: Led24970dvdfh
                    http://elektrotanya.com/vestel_17mb6.../download.html
                    tom would this work ?
                    at the moment im still waiting for the tv to reset so i can access the menu still stuck on colours when i turn it on
                      Re: Led24970dvdfh
                      Is your product code "6750407"?
                      There's little harm in trying I suppose, as you can always update the firmware on these with button presses on the TV... although do not interrupt it, as you could damage the bootloader, which would "brick" the TV.
                      • sordids999
                        • May 2013
                        • 2152
                        Re: Led24970dvdfh
                        wheres the product code on main board ?
                        found three of these so far
                        • sordids999
                          • May 2013
                          • 2152
                          Re: Led24970dvdfh
                          dam i got into service mode but for some reason its in read only mode so you cant change anything anyway
                            Re: Led24970dvdfh
                            Try menu 7935 instead.
                            • sordids999
                              • May 2013
                              • 2152
                              Re: Led24970dvdfh
                              cheers m8 ill try it but the menu option has gone from 10-15 secs to 3 secs so ill leave it off a while and try in the morning
                              • sordids999
                                • May 2013
                                • 2152
                                Re: Led24970dvdfh
                                ok 7935 just takes you just into another menu not really helpful but got back into service menu chose option 1 but everything is in read only mode it seems you cant change nothing
                                oh well i think ill buy a replacement board
                                thanks anyway
                                • Woodsworth
                                  PS3 CECHC03 60GB YLOD Troubleshooting
                                  by Woodsworth
                                  I have a post on psx-place for this but thought I'd try here as well in case anyone has experience or the schematics or any kind of help. Here's the original post from psx-place:
                                  START
                                  Hi, so I bought a YLOD Fat PS3 as I wanted a repair project and thought it would be a good way to get experience. I was able to solder to the RX, TX and Diag pads on the COK-002 motherboard and was able to get external access and retrieved the codes. I haven't powered it on beforehand so these should be the last ones. I did try to get internal access immediately after but kept getting scopen response...
                                  03-19-2024, 07:58 AM
                                • cstout
                                  DeLonghi AC Remote only accepts 3V
                                  by cstout
                                  Hello all, I've been looking into this portable air conditioner's remote control and can't find what could be causing the problem - or possibly this remote is just terribly designed.
                                  The remote only works at exactly 3V - if I drop it any lower, using my bench power supply, to say, 2.9V then the remote will not flash the display and turn off. I don't have any AAA batteries that are exactly 1.5V each so I'm not sure if this remote is designed this way - to only use the freshest possible batteries, or if there's a failed component in the mix.
                                  I can't find any schematics...
                                  06-03-2024, 03:53 PM
                                • Mc_Millian
                                  Toshiba 50lf711u20 fire tv remote not pairing
                                  by Mc_Millian
                                  I was wondering if anyone could help my in pairing a remote with a Toshiba fire tv?
                                  The Tv model number is: 50lf711u20 Rev B.
                                  I've already replaced all the the circuit boards within the tv along with the I.R. sensor receiver.
                                  I've tried 3 different remotes which should be fully compatible with this TV.
                                  Oddly enough. A few if the buttons on all of the remotes actually work. Even without pairing...which makes no sense.
                                  The power button, along with the volume,back,select, and directional...
                                  04-07-2022, 12:15 PM
                                • rustinjust
                                  Please help, where can I get a remote for my subwoofer?
                                  by rustinjust
                                  I’ve got a subwoofer that I’ve had for nearly 20 years, it did come with a basic remote which I’ve lost. It’s a generic make of subwoofer, I can’t see a brand sticker on it. It comes with 2 speakers.
                                  Question recently I’ve connected it up to my tv which has greatly improved the sound on my tv, however I’d like to be able to mute the subwoofer when ads come on or just mute it when the phone rings etc. I tried using a cheap all in one tv remote on the subwoofer and the volume button would only work to increase volume but not turn it down or mute it
                                  Is there...
                                  10-28-2023, 03:43 AM
                                • codycowgill
                                  Lost christmas tree remote
                                  by codycowgill
                                  I have a rgb "holiday symphony" 600 led tree that I got for free but it has no remote which basically neuters the tree with just one color option and no music. The original remote is as 433.96 mhz rf remote. Here is the fcc link: https://fccid.io/2APJZ-PDT0093V.
                                  The manufacturer is Polygroup and are absolutely no help. As they offer no replacements to the most easily lost part. All they gave me was the model number of the remote and said google it and good luck. Of course nobody is selling them. Anyways I provided pictures of the reciever motherboard along with the rgb...
                                  12-31-2022, 06:22 PM
