PL51D550C1G Plasma Samsung - No picture, but sound is ok
    replied
    Re: PL51D550C1G Plasma Samsung - No picture, but sound is ok
    Can you share a picture of the fault?
  • rogerazambuja
    replied
    Bad news: Suddenly appeared vertical bars on the screen in random colors and the TV turns off by itself after a few seconds.
    What could be the problem now?
    replied
    Originally posted by rogerazambuja
    It doesn't say the current, but it is a 120mm Akasa ultraquiet amber fan (2-ball bearing) 12V DC 1400RPM. I can measure the current with my multimeter if it is necessary, but I think it is very low current.
    You'll need the current to determine the resistance needed.
    Assuming 0.07A which is fairly typical, the fan will run quietly and have reasonable airflow at 7V, so you want 8V drop across resistor at 0.07A: 114 ohms (R = V/I), 100 ohms is close value and the resistor will dissipate about 0.49W (so select a 1W or higher resistor and place it in the airflow to help cool it.)
  • rogerazambuja
    replied
    Originally posted by tom66
    Place it above the Y-main so it blows air out the top of the TV. What is the rated current of the fan? (e.g. 12V 0.076A DC printed on it, rated current is 0.076A or 76mA)
    replied
  • rogerazambuja
    replied
    There is a 15V line on the Y-main marked "Vg". You can use a resistor to limit the fan speed as 15V will be too loud.
    What should be the resistor's impedance to result in 12V? Is it better to put this fan as an exhaust, to take off the heat inside my tv?
    replied
  • rogerazambuja
    replied
    Guys, I want to put a PC cooler in my plasma TV, because I think the y board blew up because of the heat.
    I have a 120mm fan, i just need a 12v line on the tv to power it.
    There is a 12v line on this TV?
    replied
    Nice!
  • rogerazambuja
    replied
    Update: I replaced the y-main board and my TV is working now!
    Thanks a lot everyone for helping.
  • rogerazambuja
    replied
    Just one more question, I just bought the Y-main board and it is Rev 1.5. My TV Y-main board is Rev 1.2, it will gonna work? I didn't find a Rev 1.2 board to sell.
    PS: The seller said it will gonna work.
  • rogerazambuja
    replied
    Will these guys ship to you?
    http://www.ebay.co.uk/itm/SAMSUNG-Y-...item3390645e5b
    What's import tax like, something around 200% from what I've heard ?
    Yes, they ship. I don't remember what is the import tax here, because everything that i've bought from other countries never was taxed (but I know that it happens often, maybe I'm lucky).
    The problem is that things that come from outside Brazil, stays a long time at inward office of exchange (3 months sometimes) in order to check what it is and maybe tax it or not (Yes, third world problems).
    I think I'm gonna buy here in Brazil, it costs 200 Reais (US$78 or £52), almost the same price. But thanks a lot for helping tom66.
    replied
  • rogerazambuja
    replied
    Nobody?
  • rogerazambuja
    replied
    This is the board I need: Samsung BN96-16524A (LJ92-01764A) Y-Main Board
    A real picture of my board:
  • rogerazambuja
    replied
    Begins with LJ, but i'm not at home right now. I will check and post here soon.
    replied
    What is the part number on the board? begins with "LJ" or "BN".
  • rogerazambuja
    replied
    Update: i went to the shop where the tech who said that the problemas was the screen, and he confessed that the problemas is the y-main board. He changed the board then the screen worked.
    Can you guys tell me some trustable websites where I van buy this board (and ship to Brazil)?
    replied
    It is possible to have a micro fracture cause a silent leak of panel gas. But usually the crack is visible. Very hard to tell unfortunately.
  • rogerazambuja
    replied
    Update: i took my TV to another tech and he said that the problem is bad panel.
    So I have 2 diagnostics: x and y boards or bad panel.
    Is it possible to have a bad panel even without any visual cracks on it (visually the panel is perfect), specially after a big "explosion"?
  • TR103
    by TR103
    - it keeps rebooting
    01-22-2025, 04:12 PM
  • Mgiffune
    by Mgiffune
    06-09-2024, 10:28 AM
  • Ierwin
    by Ierwin
    05-13-2025, 03:31 PM
  • jchang
    Samsung UN70NU6900F no picture and no sound
    by jchang
    Hi all
    I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
    Symptom:
    No picture no sound.
    When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
    No sound at all.
    What I tried:
    1. I tried unplugging the left or right ribbon...
    01-09-2023, 06:28 PM
  • Dodgethis
    Samsung QN75Q6DRA, No Picture, Has BL, and Sound
    by Dodgethis
    Hello all,
    This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
    09-11-2024, 07:39 AM
