PL51D550C1G Plasma Samsung - No picture, but sound is ok
  • rogerazambuja
    replied
    Re: PL51D550C1G Plasma Samsung - No picture, but sound is ok
    Originally posted by tom66
    You are probably using AC mode on your meter - measure them on DC.
    Out of interest does it do this on the test pattern?
    Control board might be detecting a fault or sending a signal to the main board to shut down PSU.
    I wouldn't rule out the possibility but most likely it's just a case of bad luck and poor Samsung build quality.
    Lol, I'm a retard! I was really using AC mode. I'm so angry about this that I didn't even notice.
    No, the TV doesn't turn off by itself when is in pattern test mode.
    I did try unplug and plug all ribbon cables but it doesn't work. I think it is probably logic board like you said
    Unbeliveable!
    replied
    Originally posted by rogerazambuja
    Understood. But it could be the cause of the TV turning off by itself after a few seconds?
    I'm just thinking... what a bad lucky I have, because I just changed the Y-main board 2 weeks ago. My TV was working perfectly, then the control board fails? This supost control board fail could be related with the previous fail (Y-main board fail)?
  • rogerazambuja
    replied
    I checked some voltages on my TV when it is on pattern test and they aren't normal: VS ~450V; VA ~125V; Ve ~180V;
    They should be: VS 205V; Va 58V; VE 80V;
    This is not normal, right?
  • freakaftr8
    replied
    I highly doubt its related. However there could be a very slight possibility
  • rogerazambuja
    replied
  • rogerazambuja
    replied
    Originally posted by freakaftr8
    I'm with Tom its most likely a control board or ribbon cable connection. I remember some of the older LG 42 inch PDP having the blue red green stripe syndrome from a bad control board processor BGA connection. That blue bar on the far left side is a clear indication of a control board fault and that would make sense it partially part of the screen is blank. Normally I would be saying bad panel but I think the control board is most likely the cause. especially since you have random pattern of distortion that are equally spaced in line with the picture
    replied
    But the panel was ok, after I changed the Y-main board the picture was perfect! Then yesterday after I turn on my TV this problem happened. I suspect that maybe the Y-main board failed again or the X-main. Do you think this is possible?
    No, the Y-main/X-main can't cause a fault like this. I think the control board is more likely I'm just not ruling out a panel fault. Panel faults can be spontaneous (as can control board faults, for that matter.)
  • freakaftr8
    replied
  • rogerazambuja
    replied
    I would say about 80% control board, 20% chance plasma panel has failed (sadly Samsung panels seem to fail quite frequently.) That large chip on the control board, try pressing on it firmly and see if the problem clears. Also check all ribbon cables are seated right, especially note that long screws from some wall mounts/stands can damage these cables.
    replied
  • rogerazambuja
    replied
    Here is some pictures during the patterns test:
  • rogerazambuja
    replied
    Ok,
    Unplug all power to set.
    Top right 2x2pin header (4 pins exposed) jumper pins 3 and 4 with a wire/HDD jumper/etc
    Then disconnect right most orange "LVDS" cable.
    Plug set in and take TV out of standby using remote. What do the test patterns look like?
    I did this before but the distortions are still there
    replied
    Ok,
  • rogerazambuja
    replied
    ok, can you supply a photo of your control board. It's the small green board in the middle of the set with the blinking green light on it.
    replied
    Ok, can you supply a photo of your control board. It's the small green board in the middle of the set with the blinking green light on it.
  • rogerazambuja
    replied
    Hmm. That is odd. Those distortion areas, are they always there, no matter the content? Do they ove? And the black bar area, is that always black, and is it fixed?
    Did you unplug/replug anything before this fault occurred e.g. y-main connector or did it just happen suddenly.
    They are always there, no matter the content. The black bar is always there, and there is a blue bar in the left corner just like the picture. Sometimes the TV get crazy and change the channels by it self quickly and doesn't respond the remote and the panel buttons.
    After a few minutes the TV turns off by itself.
    PS: I unplugged the X-main board and now the TV doesn't turn off by itself, but of course, there is no picture.
    replied
  • rogerazambuja
    replied
    can't view imgur here, can you upload using "manage attachments" feature?
    Sure.
    replied
    Can't view imgur here, can you upload using "Manage Attachments" feature?
  • rogerazambuja
    replied
    Can you share a picture of the fault?
    Can you see the picture now?
  • TR103
    by TR103
    - it keeps rebooting
    01-22-2025, 04:12 PM
  • Mgiffune
    by Mgiffune
    06-09-2024, 10:28 AM
  • Ierwin
    by Ierwin
    05-13-2025, 03:31 PM
  • jchang
    Samsung UN70NU6900F no picture and no sound
    by jchang
    Hi all
    I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
    Symptom:
    No picture no sound.
    When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
    No sound at all.
    What I tried:
    1. I tried unplugging the left or right ribbon...
    01-09-2023, 06:28 PM
  • Dodgethis
    Samsung QN75Q6DRA, No Picture, Has BL, and Sound
    by Dodgethis
    Hello all,
    This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
    09-11-2024, 07:39 AM
