SAMSUNG -UE40ES6300- Horizontal pixel line
  • donst
    • Nov 2013
    • 56
    The TV has a thin pixel line running right across it, could it possibly be the T-Con board? Do i need a replacement panel? All help appreciated, purchasing replacement panels would not be an issue.
    Pictures attached.
  • DemonBG
    • Mar 2012
    • 143
    Re: SAMSUNG -UE40ES6300- Horizontal pixel line
    A single line of pixels will typically be a panel issue from what i have gathered...
    It may be worth trying to re-seat the connections between all the boards and seeing if it helps?
    Good luck.
    • chrismurphy
      • May 2014
      • 251
      • australia
      Pictures attached.
      Not T-con as per other post bad connection on panel but suspect bad panel
      • Ihandyrepair
        Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
        by Ihandyrepair
        Hi guys
        I just started fixing 4k TV few months ago. so I am still learning a lot
        I got this tv from friend complaint is ghosting or horizontal lines on image.
        never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
        then it started to show the ghosting white image.
        I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
        it has 3 thin small boards at the bottom of the...
        12-05-2022, 04:18 PM
      • cubytus
        Samsung UN50TU8000FXZC shows thin horizontal green line when warm
        by cubytus
        Hi to all,
        I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
        I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
        Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
        01-10-2024, 01:26 AM
        09-07-2024, 05:50 AM
      • howardc64
        by howardc64
        07-24-2025, 05:17 PM
      • kotel studios
        Samsung LC32HG70QQUXEN - vertical and horizontal stripes across the screen
        by kotel studios
        Just now my Samsung LC32HG70QQUXEN monitor gave up on me. On cold boots I get many vertical stripes going across the screen (see the attached picture). After it runs for 1-2 minutes those go away but there are horizontal stripes going across the whole screen no matter of the input and PCs I use. (couldn't take an picture of it since the image size goes to 20MB and the camera doesn't pick them up)
        In a video about a 27" monitor with an similar issue the guy removes one resistor and supposedly the entire monitor goes back to life? For sure this fix is only temporary....
        08-06-2025, 02:07 AM
