ps51e450 sound but no picture
  • wreksta
    • Aug 2013
    • 508
    • england
    hi all I have a Samsung ps51e450 that has no picture I have sound
    I have checked the vs and va coming from power board they sit at 10.6 vs and very low for va I disconnected the x-y main from the power board and get no voltages
    from vs-va testpoints
    ive checked main board to power board and all voltages are correct
    any ideas if its the main or the power board
    Re: ps51e450 sound but no picture
    Check vs and va as set powers on - it will probably fire them briefly then cut out. Try with and without y/xmain.
    If it does check control board for error led (flash every 5-7 sec vs every second when ok)
    • wreksta
      • Aug 2013
      • 508
      • england
      Hi tom the vs and va fire full then drop and I think the led does light every 5-7 seconds also tried without the x-y connected and get no voltage
        Ok, you will have to check Vscn and Ve.
        Also check plasma panel very carefully for cracks in the screen, especially around the edge, you know the drill.
        • ygorsan
          by ygorsan
          🧩 Problem Summary:
          • I
          07-28-2025, 08:34 AM
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
        • cheeky2
          by cheeky2
          05-25-2024, 03:27 AM
        • mrautom8
          Samsung TV UN75H6350AFXZC main board schematics?
          by mrautom8
          Schematics for the main board needed please. Sticker on board states BN94-07517A but the silkscreen says BN41-02157B. Cant find here or anywhere on the web.
          Backlights work when main boards disconnected. When connected and power button switched, the relay on the PSU board turns on for one second then back off.
          While relay is on, all voltage rails are present and steady (scoped) on main board.
          I love a good logic puzzle but getting lost without any schematics.
          No shorts on ANY capacitor main board.
          Thermal camera shows 3.3V inductor getting warm instantly but...
          10-19-2025, 06:32 PM
        • Asraf Atb
          Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
          by Asraf Atb
          Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
          Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
          I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
          01-27-2025, 05:02 PM
