Re: zenith Z50P3 PLASMA TV screen issues pink and purple grainy no image
parts are hard to find
not only does it have to be zenith model z50p3 but it has to have the same model code 50pc3db-ue and the same panel code pdp50x40a36
its most people dont have this detail when selling parts...and apparently its needed
this tv is driving me nuts....im ready to toss it out in the lake lolLeave a comment:
Can we give him the link? This one's been a battle, I'm having trouble finding that video. Is it in the sticky?Leave a comment:
Do a search for user "tom66" and "buffer testing" or similar and you will find a video of exactly what you're looking for.Leave a comment:
fyi 5v to chassis i dont even get nonsense reading i get 0vLeave a comment:
and 1 z baord cost 65.00Leave a comment:
i have bought 3 y boards...which was about 200.00 total
1 control board 40.00
2 y buffers ...75.00
and about 100hrs of time over 4 yrs on and offLeave a comment:
no matter what cost i would like to get these tvs to work..im way to deep in cost and at this point cost doesnt mean anything i would like to know what is actually causing this issue so i can learn and maybe help someone else down the line and save lots of hassle like i have gone through and i appreciate all your help....Leave a comment:
as far as the ysus this is what is on shop jimmy when i search ebr38448902 which is what was in tv when i got it...when i search z50p3 no ysus shows up in their parts for the model tv but when i search ebr38448902 it does show up with sub parts and currently i have installed the ebr39522801 which has same connectors but different design/layout... which i just bought off ebay few days ago...with no success but i do have (2) ebr38448902
SKU sj-EBR38448902
Warranty 180-Day Warranty
Part Type Y-Main Board, YSUS, Y-Sustain
Part Number EBR38448902
MFR Part Number 1 LG EBR38448902
Board Number(s) EAX34042601
Substitute Parts EBR39522801, EBR38050002, EBR36223601Leave a comment:
and like i told tv2005
the buffer set i have in there now is odd. 38447802 and 602
these are what was in there when i got tv....but now looking at shop jimmy neither of those show up under z50p3
but 3 yrs ago thats what shop jimmy sold meLeave a comment:
when i did the tests today i did not have the buffer cable connected to buffer i disconnected it
was this ok? should i have buffer cable connected to y when doing this?
and do you want me to test 5v to vfg pin on same connector??Leave a comment:
Can you repeat with the buffers removed?Leave a comment:
what should i test now......note i have. swapped out 3:ysus.....all same results
are all ysus bad?...or all good with other issue?
bad zsus?
note
swapped zsus .same resultLeave a comment:
correction resistanceLeave a comment:
update with tv powered on i checked pin 2 5v to pin 1 ground on power cable from y to y buffer...reading 0v
also did same 5v and neg to the metal connector thay atyaches both boards...reading 0v
also did resistence test pin 2..pin 1...reading 0...or no readingLeave a comment:
I'd like to probe those signals sometime, but it would require a high speed differential scope probe. Which I don't have. Would be useful for tracking down odd faults with Y-buffers.Leave a comment:
VFG to 5VF should give about 5V, but GND to 5VF (with GND being chassis) will just give a nonsense number because you're essentially just measuring the Y-sus output plus 5V... and the Y-sus output is not a DC level but a complex multi-step waveform and it changes based on the current image.
I guess you've done little with these too? Nothing leaping out from the photos or what's been done?Leave a comment:
VFG to 5VF should give about 5V, but GND to 5VF (with GND being chassis) will just give a nonsense number because you're essentially just measuring the Y-sus output plus 5V... and the Y-sus output is not a DC level but a complex multi-step waveform and it changes based on the current image.Last edited by tom66; 11-24-2014, 07:02 AM.Leave a comment:
by Vlad713Hello everyone,
I am struggling with an issue on my LG TV, as mentioned in the title - please see the attached photos.
The display / panel has been replaced in March 2023, under warranty - right before expiring after 2 years of use - due to a bunch of dead pixels.
Then in a few months the purple / pink line started showing up, however the LG service said that this is not covered by any warranty, anymore, since the original one has expired.
Recently I have just asked a repair firm to have a look and they have said that the panel needs to be replaced,... -
This specification for the Acer Swift Acer Swift 3 SF314-42 14 inch Laptop - (AMD Ryzen 5 4500U, 8GB, 512GB SSD, Full HD Display, Windows 10, Purple) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 SF314-42 14 inch Laptop - (AMD Ryzen 5 4500U, 8GB, 512GB SSD, Full HD Display, Windows 10, Purple) boardview and Acer Swift 3 SF314-42 14 inch Laptop - (AMD Ryzen 5 4500U, 8GB, 512GB SSD, Full HD Display, Windows 10, Purple) schematic. Our users have donated over 1 million...09-07-2024, 12:40 AM
This specification for the Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) boardview and Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) schematic. Our users...09-06-2024, 09:30 PM
by jimjoe123I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
Then each time... -
by YellowJacketHi friends,
I got this monitor, which works perfectly fine, except there is pink discoloration over right side of the screen ( picture1 ). When I disconnect LVDS cable, there is no sign of pink color, so its not backlight issue ( picture2 ). I took a closer picture of the upper right corner, you can see even some kind of pixel defects. Its only on that pink area ( picture3 ).
I believe, there is some problem inside the panel, the question is, if it is fixable. I have never met this kind of issue, so I really appreciate little help from you guys. What I tried so far - interrupt...-
08-17-2023, 11:45 PM -
- Loading...
