Help all (1st time post):
I've gained a little bit of knowledge on this TV from searching this forum and other internet sources, and think I've partially figured out that SU & SD boards are bad, SC probably is, but that A might also be faulty.
Here's what I've done:
1st,
-isolated SU board, resistance was 1.08Mohm (spec 2.1)
-isolated SD board, resistance was 1.06Mohm (spec 2.1)
-isolated SC board, got no or variable readings for resistance
-at power up, went to 7 click sequence
2nd check,
-put jumper on SC50 (stuck alligator clip on 2 pins)
-removed ribbon at TP82
-at power up, went to 8 click sequence
-So now, does this mean the A board is bad also? I also tried this test w/o the jumper clip at SC50, but same result.
Am I doing anything wrong with the test procedure? It appears I need SU, SD boards (some available used) and get the SC repaired. If I have to do A board also, it appears to be getting uneconomical to fix this TV.
Oh, and I've only limited electronics experience, this TV and another are a buddies that I'm taking a flyer on fixing (we each keep one if they can be fixed).
Thanks in advance,
Fran K
1st,
2nd check,
Thanks in advance,
Fran K
