samsung le32a457 bad cap symtoms but look okay
  • steveo3002
    • Nov 2014
    • 23
    • england
    hey all
    found this site from googling how to repair my samsung le32a457 tv , its started to turn itself off and now sometimes takes a while to turn on again
    many sites suggest its blown caps
    ive taken it apart and i have no swollen caps , no leakage apart from one dot that looks like sharpie ?
    is it possible theyre starting to fail and havent swollen yet? if so could someone please help identify which ones i should replace please
    i can get all the pics you need ..just tell me what to take pics of
    Re: samsung le32a457 bad cap symtoms but look okay
    See attached picture, those caps in circles should be replaced, those bad glues should be removed.
    Unplug the TV from the AC outlet, then try heating the power supply board with hair dryer for a few minutes to see if the TV will start up.
    • steveo3002
      • Nov 2014
      • 23
      • england
      it comes back on if it stands for 20 mins
      ebay kits only include 4 caps..so im best to take down the ratings and replace them all
      you say bad glues? can you explain further on what you mean please , ive never repaired a tv before
      thank you
      edit ...and i should order low esr parts right?
        Bud, I seem to remember that the blue poly cap below the transformer has been a problem with this PSU before? Or am I getting mixed up with another PSU?
          Yes, that is also another common failure cap for the 24V power supply. I wonder now if he is talking about the backlights that do not always come on or the whole TV does not always turns on.
          • steveo3002
            • Nov 2014
            • 23
            • england
            whole tv turns off like you switched it off , first few times it turns on straight away , then last night it wouldnt turn on for around 20 mins or so
              So the power light on a Samsung is normally lit in standby and off when running. When it just turns off, does the standby light come back on? Or does it stay off?
              • steveo3002
                • Nov 2014
                • 23
                • england
                stanby led should be lit in stanby and off with the tv on
                when it turned off it was blank , when trying to turn on the tv it randomly flashed
                • steveo3002
                  • Nov 2014
                  • 23
                  • england
                  okay guys
                  i ordered all the parts , they came in and match the originals in size except the
                  680uf 25v is somewhat smaller than the original part , is this a concern ? maybe weaker because of the size ?
                    It won't be a concern, capacitor dimensions can vary quite a lot.
                    • steveo3002
                      • Nov 2014
                      • 23
                      • england
                      right thanks tom
                      so ive replaced the 7 big caps , tv works still
                      after approx 1 hour it turned off but came back on straight away by itself , before i replaced the caps you always had to manualy press the remote
                      so it feels ive done some good ..does the above point toward anything obvious an ametuer could look at ?
                        Where did you buy the capacitors from?
                        (Please don't say Maplin or eBay....)
                        • steveo3002
                          • Nov 2014
                          • 23
                          • england
                          was ebay
                          if it points towards crappy parts could you help me with a shopping list from elsewhere please ?
                            Did you get genuine Panasonic, Nichicon, Rubycon or United Chemicon capacitors? The general purpose ones most eBay sellers sell are absolute junk - could well cause your issues.
                            In future (I really should have mentioned this before) CPC have free delivery over £5 on any card orders. http://cpc.farnell.com/
                            Use Panasonic FM/FR/FC or Rubycon YXF (they stock both sets, typically Panasonic is slightly cheaper)
                            • steveo3002
                              • Nov 2014
                              • 23
                              • england
                              it said panasonic in the auction but theres no branding on them at all ..so assume no name jobbies
                              this is what it had
                              all 105deg
                              470uf 25v
                              680uf 25v
                              680uf 35v x 3
                              3300 10v
                              2200 10v
                              should i make the 680 25v a 35v to simplify things
                              if you get a min would you link me some correct part numbers , i dont want to get the wrong bits twice
                              many thanks
                              example of the ebay one
                              http://www.ebay.co.uk/itm/1205780820...%3AMEBIDX%3AIT
                                Do your capacitors have (M) printed on them and a series designator such as FM, FR, FC....?
                                • steveo3002
                                  • Nov 2014
                                  • 23
                                  • england
                                  from the spares i have left over
                                  3300 says 307md
                                  680 says421fv
                                  470 says ky ,m105deg 4 (k)
                                  2200 says 3714OF (possibly a q)
                                  others i cant see as theyre installed
                                  thanks
                                    I had a look at the auction, its hmcomp, I've used him before and he seemed alright (caps looked genuine too) so you should be OK then. There are many other sellers who sell fakes though so you have to watch out.
                                    These days i don't use eBay with CPC being so cheap and £5 mind order, if it's coming short I just put some solder wick on the order to bring it up. Always need some solder wick!
                                    • steveo3002
                                      • Nov 2014
                                      • 23
                                      • england
                                      righto good stuff
                                      will report back how it goes over the next couple of evenings
                                      • steveo3002
                                        • Nov 2014
                                        • 23
                                        • england
                                        okay its back to its old self
                                        random turning off , struggles or refuses to come back on , led flashes for say 40 secs then glows try again it may or may not come on
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          09-06-2024, 06:20 PM
