RCA L32WD22 recapped, but now high pitched noise
  • kevinm34232
    • May 2012
    • 1884
    The power supply needed all new caps, replaced with high quality Panasonics. It powers on normally now, but has this very annoying high pitched noise coming from it. Has anyone seen this before, the TV is a pain to disassemble. Thanks!
    (It seems to start when backlight turns on)
  • karatzdi
    Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
    by karatzdi
    I know some might say... just buy another one. Sell it as parts..!
    So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
    Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
    Spent some time downloading the Service...
    06-11-2024, 08:38 AM
  • oldmanhouse
    Panasonic TX-L50B6B | High pitched noise and black lines
    by oldmanhouse
    Hi folks, I have an issue with my 7 year old Panasonic TX-L50B6B that has appeared within the last few days.
    The symptoms are:
    • A high pitched "buzzing" / "whining" noise coming from the TV when it is turned on. There is no noise during standby, and the noise persists with all AV connections removed.
    • There are noticable horizontal lines in the picture. Upon closer inspection it looks like every few rows of pixels are dead/black.
    Attached is a close-up of the picture in "test mode", to demonstrate the rows of black lines.
    07-09-2020, 06:30 AM
  • Camarada78
    MXR Carbon Copy High Pitched Noise
    by Camarada78
    I have a MXR Guitar Pedal here that turns on, passes audio but does not add the effect. It has a high pitched squeal that varies tone depending on delay speed.
    Its a analog delay pedal using four BBD (BL3208A), one compander (SA571D), one clock (cd4047), one TL082 and one 33178.
    This pedal is prone to some issues (ESD), but i replaced the common faulty transistors and the problem remained. In fact, the original ones were still good (tested on component tester).
    Anyone familiar with this pedal to give me some light?
    06-07-2021, 02:33 PM
  • tony359
    by tony359
    11-28-2023, 05:18 AM
  • MegaZAC
    Onkyo TX-SR805 noise in one channel
    by MegaZAC
    Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
    Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
    There's some logic behind it. As soon as I select an input I get only left...
    04-23-2025, 10:09 PM
