Toshiba 26AV600A
Re: Toshiba 26AV600A
Maybe try testing powerboard, with cable from CN902 to mainboard UNHOOKED, use about a 1k resistor to jump PS_on to +5v pin and another resistor from ON/OFF to +5v, plug the power into powerboard, see if you get the backlights on and if those voltages come up.Comment
The 13 volts is ok for the ic's vcc, Check the voltage on ic970, pin 7, and pin 5 (look at the schematic and locate a nearby component to check the voltage to avoid shorting the ic pins (IE: pin5 use C991 orR992)
It could be that IC870 is bad.Comment
I don't believe the optocoupler is the problem
The datasheet says that pin 4 provides a 2v reference voltage which should show up on one end of R932, This voltage is from the ic itself so I suspect if it is missing the ic is the problem. If the optocoupler is not shorted, then the 2 volts from pin4 should go through R932, R992 and back to pin5 (the standby pin) and should be around a minimum of 1.3v
It seems the circuit is slightly working and likely stuck in burts mode. otherwise you shoud not have any voltage on the 24v1 supply, this is where pin1 of the optocoupler gets its voltage and is getting 2.91v.Last edited by R_J; 05-29-2020, 06:21 PM.Comment
Cheers R_J and everyone else a new chip solved the issue and bought the TV back to life.
This TV bought some different symptoms to the table for when this chip goes bad anyway.Comment
by semiRocketThe set is not turning on, when buttons on the front are pressed the button press sound is coming from the speakers, but the set is not trying to turn on, consuming only couple of watts.
I am troubleshooting a Vestel 17PW26-5 from the set. Not sure how it is supposed to turn on main supply, but with the main board disconnected not getting the main supply to turn on either.
Standby supply is working, PFC is working (390V), but the main supply is dead. Checked the mosfets and driving transistors and found they are not shorted and showing a diode junction. The suspicious... -
This specification for the Toshiba Satellite L655-19C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L655-19C boardview and L655-19C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...09-06-2024, 05:59 AM
This specification for the Toshiba Satellite L635-10K Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L635-10K boardview and L635-10K schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...09-06-2024, 05:59 AM
This specification for the Toshiba Satellite L655-1DJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L655-1DJ boardview and L655-1DJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...09-06-2024, 05:59 AM
This specification for the Toshiba Portege Z30-C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z30-C boardview and Z30-C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Portege...09-06-2024, 05:33 AM
- Loading...
