Toshiba 26AV600A
  • Amraks
    • Nov 2011
    • 725
    Re: Toshiba 26AV600A
    Check all the diodes on the powerboard, good place to start and easy enough to do.
    checked over the diodes no bad readings from any of them.
    Now I’m really stuck.
    • nomoresonys
      • 12331
      • U.S.
      #62
      Maybe try testing powerboard, with cable from CN902 to mainboard UNHOOKED, use about a 1k resistor to jump PS_on to +5v pin and another resistor from ON/OFF to +5v, plug the power into powerboard, see if you get the backlights on and if those voltages come up.
      • Amraks
        • Nov 2011
        • 725
        Tried forcing it on with out the mainboard plugged in none of the voltages I was getting are appearing.
        • R_J
          • Jun 2012
          • 9625
          check R925 (0.1Ω) and R930 (0.43Ω), if they are ok, use hot ground to check the voltage on Q970 Drain (should be pfc voltage) if it is ok, check the voltage on C977 (15v)
          • Amraks
            • Nov 2011
            • 725
            r925
            0.2 Ω
            r930
            0.4 Ω.
            • R_J
              • Jun 2012
              • 9625
              The resistors are ok, so the fets are likely ok, Now check the voltages
              • Amraks
                • Nov 2011
                • 725
                So checked
                Q970
                396v
                c977
                13.18vdc
                C977 is meant to be 15 volts isn't it?
                • R_J
                  • Jun 2012
                  • 9625
                  The 13 volts is ok for the ic's vcc, Check the voltage on ic970, pin 7, and pin 5 (look at the schematic and locate a nearby component to check the voltage to avoid shorting the ic pins (IE: pin5 use C991 orR992)
                  It could be that IC870 is bad.
                  • Amraks
                    • Nov 2011
                    • 725
                    done these checks.
                    Pin 5
                    2.6mV
                    Pin 7
                    1.98V
                    • R_J
                      • Jun 2012
                      • 9625
                      It would seem the ic is in standby, pin 5 needs to be above 50mv. Check the two resistors, R932 (3.9k) and R992 (100Ω) if they are ok, check that the optocoupler is not bad and that C991 is not shorted
                      • Amraks
                        • Nov 2011
                        • 725
                        r932 is good
                        r992 is good
                        c991 isn't short
                        optocoupler isn't shorted.
                        • Amraks
                          • Nov 2011
                          • 725
                          optocoupler
                          2.91v on pin 1 using chassis as ground
                          2.0Mv on pin 4 using filter cap as ground.
                          Would it be safe to say this optocoupler is no good?
                          • R_J
                            • Jun 2012
                            • 9625
                            I don't believe the optocoupler is the problem
                            The datasheet says that pin 4 provides a 2v reference voltage which should show up on one end of R932, This voltage is from the ic itself so I suspect if it is missing the ic is the problem. If the optocoupler is not shorted, then the 2 volts from pin4 should go through R932, R992 and back to pin5 (the standby pin) and should be around a minimum of 1.3v
                            It seems the circuit is slightly working and likely stuck in burts mode. otherwise you shoud not have any voltage on the 24v1 supply, this is where pin1 of the optocoupler gets its voltage and is getting 2.91v.
                            • Amraks
                              • Nov 2011
                              • 725
                              Cheers R_J and everyone else a new chip solved the issue and bought the TV back to life.
                              This TV bought some different symptoms to the table for when this chip goes bad anyway.
                              • nomoresonys
                                • 12331
                                • U.S.
                                #75
                                So which one was bad, IC870 or IC970?
                                • Markus1
                                  • Jul 2013
                                  • 80
                                  I believe his final replacement was IC970.
                                  • nomoresonys
                                    • 12331
                                    • U.S.
                                    #77
                                    Thanks Markus.
                                    • semiRocket
                                      Toshiba 37bv701b power supply main rails
                                      by semiRocket
                                      The set is not turning on, when buttons on the front are pressed the button press sound is coming from the speakers, but the set is not trying to turn on, consuming only couple of watts.
                                      I am troubleshooting a Vestel 17PW26-5 from the set. Not sure how it is supposed to turn on main supply, but with the main board disconnected not getting the main supply to turn on either.
                                      Standby supply is working, PFC is working (390V), but the main supply is dead. Checked the mosfets and driving transistors and found they are not shorted and showing a diode junction. The suspicious...
                                      10-26-2025, 01:55 AM
                                      09-06-2024, 05:59 AM
                                      Toshiba Portege Z30-C Notebook Specification for Upgrade or Repair
                                      This specification for the Toshiba Portege Z30-C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z30-C boardview and Z30-C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Portege...
                                      09-06-2024, 05:33 AM
