LG 42PJ150. Clicking Clicking Clicking
    Re: LG 42PJ150. Clicking Clicking Clicking
    On the pin marked 17V, do you measure 17V approx?
    • Moreno83
      • Jun 2014
      • 2008
      • The Netherlands
      I dont see that pin, where should i look?
        What pins do you have? Provide a picture of the legend please.
        • Moreno83
          • Jun 2014
          • 2008
          • The Netherlands
          So this is the set, bought it from people who smoke alot as you can see haha.
          The cable on the left of the PS going to the board on the let has 0v on all pins.
          The cable on the PS righthand side is going to the maonboard and has 4v and 5v. ( 2 pins next to eachother)
          • Moreno83
            • Jun 2014
            • 2008
            • The Netherlands
            This is the cable going to mainboard
              Need a picture of the connector label of which goes to the main board.
              • Moreno83
                • Jun 2014
                • 2008
                • The Netherlands
                #27
                The last picture is the cable going to the mainboard.
                  Ok, I see it now, the two outer pins marked 17V test those with AUTO GND connected to GND.
                  • Moreno83
                    • Jun 2014
                    • 2008
                    • The Netherlands
                    #29
                    Going to measure them right now. Last time i measured without the gnd/auto gnu connected i got 0v.
                    • Moreno83
                      • Jun 2014
                      • 2008
                      • The Netherlands
                      #30
                      With Gnd/Auto gnu connected i get 0V. ( 4v/5v is still present ).
                      Also , when i bridge those 2 and i put in the mains i get click click click. When i remove the mains and put the mains back in i don't get clicks.
                        Looks like we'll have to try something else.
                        Do you have two resistors of value somewhere between 100 and 470 ohms? They can be different values.
                        • Moreno83
                          • Jun 2014
                          • 2008
                          • The Netherlands
                          #32
                          Hmm i got some spare powersupplys so there probably 2 of those resistors on it...
                          Whats the plan? You want to emulate the voltage regulator?
                            Connect M_ON to 5VSTBY, RL_ON to 5VSTBY using the resistors. Disconnect AUTO GND. Plug PSU in and see what happens. Vs/Va/17V etc.
                            • Moreno83
                              • Jun 2014
                              • 2008
                              • The Netherlands
                              #34
                              M_on to 5v with resistor and rl_on to 5vstb with resistor?
                                Yes, but both to 5VSTB
                                • Moreno83
                                  • Jun 2014
                                  • 2008
                                  • The Netherlands
                                  #36
                                  Ok , will do that tomorrow afternoon.
                                  So just be sure :
                                  A wire going from M_ON ---> resistor ----> 5V
                                  A wire going from RL_ON ---> resistor ----> 5v
                                  Any particular resistor value in mind ?
                                    Yes that's correct, any value around 100~470 ohms.
                                    • Moreno83
                                      • Jun 2014
                                      • 2008
                                      • The Netherlands
                                      #38
                                      Got the wires ready! Both 150ohm
                                      You say disconnect auto gnd. Do you mean the bridge or?
                                        The bridge between GND and AUTO GND should be removed for this test.
                                        • Moreno83
                                          • Jun 2014
                                          • 2008
                                          • The Netherlands
                                          #40
                                          Nothing changed. No 17v and no voltages going to ysus board.
                                          M on is 5,2 v
                                          R_on is 4.523v
                                          • bffargo
                                            2014 LG 60" Plasma shut down just clicking unless I disconnect 17V line to main CPU
                                            by bffargo
                                            LG 60PB66550 NOV 2014
                                            PSU: EAY63168603
                                            PCB: EAX65359531 2013.11.01 Rev:1.0
                                            Main board: EAX65399305(1.0) 13.11.27 PU42A/PA42A/PD42A
                                            Symptom:
                                            While watching, just went black and started clicking relay every few seconds.
                                            Initial diagnosis:
                                            Removing JUST the main CPU/Input PCB from circuit stops the clicking. No problems with any other boards/drivers. (Removing all other boards and only putting Main back in is all it takes to start clicking again)
                                            Deeper diagnosis:
                                            Pulling pins #1/#2 (Blue/Grey) from the connector housing...
                                            09-09-2022, 07:34 PM
                                          • alfredomfr1
                                            TV Plasma LG 60PN5000 ZSUS 15v missing
                                            by alfredomfr1
                                            All Voltages are OK except ZSUS 15v.
                                            YSUS board disconnected still 15v missing.
                                            ZSUS was replaced: 15v missing.
                                            Any help will be appreciated...
                                            04-29-2022, 11:26 AM
                                          • Sisko
                                            Onkyo-593 No power and now clicking sound
                                            by Sisko
                                            Hi all!!
                                            Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
                                            10-03-2025, 02:18 PM
                                          • B0r1s
                                            Samsung UE49KS7000SXXH - fast clicking sound in standby mode
                                            by B0r1s
                                            PSU - BN44-00878A
                                            Symptoms:
                                            The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
                                            A weak clicking sound was coming from the transformer.
                                            Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
                                            Progress:
                                            After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
                                            01-17-2023, 04:58 PM
                                          • novak2
                                            Panasonic th-42px60en plasma TV takes time to turn on and make clicking noises
                                            by novak2
                                            Hello there,
                                            I recently bought a Panasonic th-42px60en plasma TV second hand. The problem is :
                                            The TV takes time to turn on from cold (being unplugged from the night for example), it tries to turn on with the clicking sound, then shuts off, then retries and so on. The TV is still working, just it takes time to boot.
                                            From what I've read it seems to be bad capacitors on the power board, but I just want to see if anyone had the same problem with this TV.
                                            Thanks in advance.
                                            09-25-2020, 02:34 PM
