LG 42PJ150. Clicking Clicking Clicking
    Re: LG 42PJ150. Clicking Clicking Clicking
    Can't find a datasheet either....
    I'd suggest measuring across C307 (this is Vcc capacitor)
    Or trace that to Vcc pin (from positive of C307)
    Typical range, 13~18V to start, 10~15V stopping. Typical, 11~17V operating range.
    • Moreno83
      • Jun 2014
      • 2008
      • The Netherlands
      #62
      Thx Tom , will do that. Will also check for to much ...how do i say it "pressure" on components on the negative side. ( Overload ).
      • Moreno83
        • Jun 2014
        • 2008
        • The Netherlands
        #63
        Hmz strange. I tried to push the probe under the cap to get to the + and suddenly it clicked on and stayed on.
        I took some quick readings and saw that i now have all the voltage i need on the canle going to the mainboard
        ( 17v / 5v / 4v)
        Screen is still dark and i only get some yellow dots on the screen wich become more when i bent the screen. I turned it off and im going to remove the foot.
          Er... you should not bend a plasma panel. It will crack. It is not like an LCD, it is not flexible at all!
          With main board disconnected and all the jumpers in place, unplug LVDS cable linking main board and control board, then jumper the points marked EXT AUTO GEN on the control board.
          • Moreno83
            • Jun 2014
            • 2008
            • The Netherlands
            #65
            Haha i dont bend it like you think i bend it. Im leaning it backwards.
            Still strange that those voltages came back.
            The Ysus does not get any voltages. ( upper left corner cable)
            • Moreno83
              • Jun 2014
              • 2008
              • The Netherlands
              #66
              With jumpers you mean the jumpers we did before includong the new jumper?
              • maria
                • Jun 2016
                • romania
                #67
                I"m looking firmware for led tv SABA -CHASIS MODUL -17MB62-2.6
                Thank you.
                • bffargo
                  2014 LG 60" Plasma shut down just clicking unless I disconnect 17V line to main CPU
                  by bffargo
                  LG 60PB66550 NOV 2014
                  PSU: EAY63168603
                  PCB: EAX65359531 2013.11.01 Rev:1.0
                  Main board: EAX65399305(1.0) 13.11.27 PU42A/PA42A/PD42A
                  Symptom:
                  While watching, just went black and started clicking relay every few seconds.
                  Initial diagnosis:
                  Removing JUST the main CPU/Input PCB from circuit stops the clicking. No problems with any other boards/drivers. (Removing all other boards and only putting Main back in is all it takes to start clicking again)
                  Deeper diagnosis:
                  Pulling pins #1/#2 (Blue/Grey) from the connector housing...
                  09-09-2022, 07:34 PM
                • alfredomfr1
                  TV Plasma LG 60PN5000 ZSUS 15v missing
                  by alfredomfr1
                  All Voltages are OK except ZSUS 15v.
                  YSUS board disconnected still 15v missing.
                  ZSUS was replaced: 15v missing.
                  Any help will be appreciated...
                  04-29-2022, 11:26 AM
                • Sisko
                  Onkyo-593 No power and now clicking sound
                  by Sisko
                  Hi all!!
                  Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
                  Yesterday, 02:18 PM
                • B0r1s
                  Samsung UE49KS7000SXXH - fast clicking sound in standby mode
                  by B0r1s
                  PSU - BN44-00878A
                  Symptoms:
                  The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
                  A weak clicking sound was coming from the transformer.
                  Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
                  Progress:
                  After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
                  01-17-2023, 04:58 PM
                • novak2
                  Panasonic th-42px60en plasma TV takes time to turn on and make clicking noises
                  by novak2
                  Hello there,
                  I recently bought a Panasonic th-42px60en plasma TV second hand. The problem is :
                  The TV takes time to turn on from cold (being unplugged from the night for example), it tries to turn on with the clicking sound, then shuts off, then retries and so on. The TV is still working, just it takes time to boot.
                  From what I've read it seems to be bad capacitors on the power board, but I just want to see if anyone had the same problem with this TV.
                  Thanks in advance.
                  09-25-2020, 02:34 PM
