Philips 32PFL5332D/37 Issues
  • Audioplus
    • Feb 2012
    • 157
    Client has an issue with their Philips LCD, they have power and backlight.
    ' I have to turn it off and on a couple times to get the picture to connect. you can see the back light when its turned on without picture.'
    They unplug and re-plug a few times and eventually get a picture.
    T-Con board? or Main Board? I assume it's not an inverter issue.
    Thanks,
    Dan C
  • Audioplus
    • Feb 2012
    • 157
    Re: Philips 32PFL5332D/37 Issues
    Have an associate that suspects a PS issue, Philips power supplies use rather robust caps, that powering off and repowering may push enough storage capacity to fireup the T-Con and main board to display an image?
    Anyone concur?
    • charlesdutcher
      No picture issue in Philips Chassis FTL2.1
      by charlesdutcher
      My Plasma Philips 37inch chassis FTL2.1 does not show picture. It automatically goes into protection mode after 30 seconds (red led blinks at 3Hz)
      Is there someone having any symptom like this? How to fix it?
      Thanks in advance!​
      08-06-2024, 09:55 PM
    • Tr0ll
      by Tr0ll
      Original T-con:
      First replacement T-con:
      10-07-2023, 07:48 PM
    • CyberPhoenix
      Issue with picture quality of Sony bravia TV
      by CyberPhoenix
      Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
      01-22-2024, 02:08 AM
    • Patrick501
      Philips 55PUS6704 no picture, backlight ok
      by Patrick501
      I'd like to repair a Philips 55PUS6704.
      It turns on and you can see the backlight, hear the sound but no picture.
      When I disconnect one of the T-con cables, half of the screen turns white.
      right cable disconnected= right side white
      left cable disconnected= left side white
      When I tape like 6 or 7 pins of one cable it looks like the picture attached. I already tried another T-con board without success.
      There are no shorts on the the mainbaord and the two lcd panel boards...at leat I couldn't find any.
      Also you can notice one single...
      11-12-2025, 08:46 AM
    • madyoyo
      Philips 37pfl560: Yellow picture
      by madyoyo
      HI.
      I have a weird problem with an old Philips 37pfl560 TV i put out of storage: the picture have a noticeable yellow hue, and its not caused by the settings (did a factory reset). I've never seen this before. I will try to get a photo with a real camera, with my phone its hard to see because of automatic white balance, but in real live the whites are really yellow.
      Anyone have an idea of what can cause this? Can CCFL tubes get "warmer" with time? This tv have several analog inputs,so its nice for retrogaming....
      05-30-2025, 10:16 AM
