Samsung LE32M87BD LCD TV Screen Issue
  • safesurfer65
    • Feb 2014
    • 112
    • Scotland
    Hi
    Got a 32" Samsung LCD TV (LE32M87BD) with a screen issue. Has sound but the screen is corrupt. I can vaguely make out the menu box. After about 20 minutes the picture becomes good and stays good until it is switched off. This TV has an additional scaler board BN41-00895B. I reckon this or the T-Con board is faulty. Any experience or ideas with this ?
    See attached images.
    Mark
    Re: Samsung LE32M87BD LCD TV Screen Issue
    Since it's time dependent, therefore probably temperature dependent, did you try heating up parts with a hairdryer, see if problem clears sooner?
    • safesurfer65
      • Feb 2014
      • 112
      • Scotland
      Hi Tom
      Ok I'll try that and let you know how I get on.
      Many thanks
      Mark
      • safesurfer65
        • Feb 2014
        • 112
        • Scotland
        Tom
        Thanks for you tip regarding the hair dryer. I tracked it down to the scaler board which unfortunately is a rather tricky part to find (obviously a common problem with this model of Samsung TV) as everywhere is out of stock.
        Thanks for your help. Much appreciated.
        Mark
          I believe there's a common issue with failed capacitors on that scaler board. Might be worth trying to locate which component is faulty with careful heating through a card board tube or hot air gun.
          • ScHAmPi
            Samsung UE48JU7000 screen issue after backlight replacement
            by ScHAmPi
            Because of two bright spots and a couple of dark spots I decided to replace the backlights in my Samsung UE48JU7000. See attached photos:
            I thought all went well, but after full assembly and testing it out it turns out not all is fine. The backlights are completely fine but I have some weird issues on the right half of the screen. Since I didn't really touch the T-CON board (apart from taking out the ribbons of the display and reconnecting them on assembly) it would be weird that the issue is with the T-CON board... But based on the behavior of the service...
            07-15-2024, 05:41 AM
          • Chrissygizmo
            by Chrissygizmo
            02-10-2025, 12:33 AM
          • Chrissygizmo
            samsung galaxy ao2s very temperamental after screen replaced
            by Chrissygizmo
            Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
            Ive eventually managed to get it on and working but it's very temperamental...
            The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
            05-26-2024, 12:05 AM
          • wizard13
            Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
            by wizard13
            I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
            I have checked the forum and the available documentation but could not find a solution specific to my issue.
            • Brand & Model: Dynabook Satellite Pro C50D-B-100
            • Part Number (P/N): PYU13E-00C00PFR
            • Serial Number (S/N): 22028896H
            • System Configuration (SC): A1PYU13E1127
            • Motherboard Model: IP3_ACN16_MB_V21_20211222A
            • Power Input: DC 19V –
            02-28-2025, 02:43 AM
          • JunkmanJimbo
            Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
            by JunkmanJimbo
            Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
            No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
            Please help. Thanks in advance!
            08-12-2025, 11:45 AM
