Replacing an i315b1-16a inverter in a Samsung TV
  • hellonpluto
    • Oct 2014
    • uk
    Hi
    We have a 32" Samsung TV (le32r88bd) that is doing the 2 second to black.
    I've read the stickied thread regarding diagnosing the problem.
    I have ordered a refurbished inverter board for a whoping £6.80.
    I noticed the high voltage signs on the board which got me scared. The television has been unplugged for about a week now. Is it safe for me to start unplugging all of the connectors to replace the entire board?
    If its not the inverter board thats at fault we'll probably stick the telly on ebay.
    Hope you can help
    Thanks.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Replacing an i315b1-16a inverter in a Samsung TV
    Originally posted by hellonpluto
    Hi
    Hope you can help
    Thanks.
    Should be fine to replace the inverter and unplug the cables, the voltages discharge within about 10mins, when on the the inverter is on it produces over 1000v so stay away from it when on.
    • hellonpluto
      • Oct 2014
      • uk
      Great thanks for the speedy response!
      I thought it would be safe after leaving for a while. Did not know how long these things hold charge for.
        The output voltage of the inverter is essentially inactive as soon as power is pulled. You should be fine.
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Thats alright keep us updated
          • hellonpluto
            • Oct 2014
            • uk
            Replaced the inverter board today and all working!!
            So happy to fix it!
            Thanks a lot
            Suspected faulty inverter is now on ebay. You never know someone may buy it for spare parts.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              So happy to fix it!
              Thanks a lot
              Good to hear enjoy your set
              • bs00944
                • Jul 2015
                • Greece
                So happy to fix it!
                Thanks a lot
                could you please tell me where did you get the second hand inverter?
                I also have the same problem.
                Where can I buy one new or second hand?
                Thanks!
                • ohren
                  Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
                  by ohren
                  I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
                  I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
                  The models launched in 2018 and 2019 respectively....
                  09-08-2023, 05:24 PM
                • C152Heavy
                  Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
                  by C152Heavy
                  Summary for TL-DR readers:
                  • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
                  • Have obtained Samsung schematic & service documents - Can upload if helpful.
                  • Have read ALL applicable threads
                  • C1818 and CP820 replaced as low hanging fruit
                  • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
                  • VCC pin (18) of PFC...
                  01-11-2023, 02:53 PM
                • MacGyver's paperclip
                  what to check before replacing hybrid MOSFET/controller IC on SAMSUNG TV power board
                  by MacGyver's paperclip
                  TLDNR; Have an old SAMSUNG TV with blown hybrid MOSFET/controller IC on power board to be replaced; replaced blown main capacitor on same power board several years ago successfully, and TV has been working fine since until this IC popped all of a sudden. Want to know what if anything to check on board to make sure before replacing and testing with new IC. Have 2 new matching ICs, DIP socket to make removal/replacement easier, a whole other known-good power board with which to compare, if necessary.
                  07-01-2023, 12:12 PM
                • madyoyo
                  Samsung UE43J5500: Replacing main board by another model or screen size
                  by madyoyo
                  Hi everybody;
                  The main board (bn94-09121q) on my UE43J5500 is dead. I can't find the exact same board for a reasonable price, but some other part numbers are pretty cheap, they are physically identical, and based on the bn41-0235 board
                  Can i swap the bn94-09121q by another "letter", like a bn94-09121N, or even from anoter screen size?
                  12-27-2022, 04:15 PM
                • rblack711
                  Samsung LNS4092DX/XAA Inverter Board Connector
                  by rblack711
                  I've seen many electrical connectors, but not this type and it has me stupified as how to disconnect it from the board. This is connector CN104 on the left side inverter board (SIT400WD20B00). I've tugged and pryed it and no luck getting it off. Don't want to break it. It almost appears that the entire thing is mounted to the board and the pinned wires were latched into it one by one, but surely that can't be the case. Making me feel pretty stupid! Anyone have any idea what the trick is?...
                  04-15-2022, 12:13 PM
