HITACHI L42VK04U Won't turn on, interface still responds
  • Sathhin
    • Oct 2014
    • 8
    Hi guys,
    I've got a hold of an HITACHI L42VK04U, the machine will not turn on at all. However the touch sensitive buttons do emit a tone each time you touch them, like they should. The machine has a Vestel 17MB65-2 mainboard and a 17PW26-5.
    After testing the power supply I've found that the standby votages seem to be okay, ie the 5V and 3.3V. I also checked D881 (I believe that is the correct number, it's next to C850 and C991) and that is working fine. There's no tell tale signs of bulged capacitors either.
    Could any advise me on where to go from here please?
    TIA for any help
    http://www.technciallysmart.co.uk - Some helpful info under Fix It Yourself
  • Sathhin
    • Oct 2014
    • 8
    Re: HITACHI L42VK04U Won't turn on, interface still responds
    Just an update but I tried pulling the ST_BY both high and low and I couldn't get the 30V and 24V lines to do anything so my guess is that the power board is the issue. Anyone care to confirm this before I order a new PCB? Cheers again
    • Sathhin
      • Oct 2014
      • 8
      well, it wasn't the power board. unsure why I can't get the correct voltages to appear but a replacement board does the same thing as the old one
      • pajdek
        Lenovo Y700-17ISK turn on and off
        by pajdek
        Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
        09-20-2023, 02:49 AM
      • RdeveLabs
        MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
        by RdeveLabs
        To all the members here...
        Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
        So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
        05-05-2025, 04:59 AM
      • masoksian
        Dell latitude e7470 not turn on .power buton on off and Run Power problem
        by masoksian
        I am dealing with the problem of turning on and off my Dell e7470 notebook.
        The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
        The system does not turn on, there is no post.
        I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
        The problem continues in the same way.
        I tried to turn on the Fn key, nothing came to the screen....
        02-15-2025, 12:08 PM
      • dqtech
        lenovo x240 nm-a091 wont turn on
        by dqtech
        i got this laptop with no power issue....i flashed the bios and laptop can turn on and use normally....but when i shut it down and rest for few minute (2-3 minutes), it wont turn on....i have to flash bios again...any idea what is the problem?...when i shutdown and suddenly press power button to turn on, it will turn on normally....problem happen when i rest the laptop 2-3 minutes after shutdown, it will not turn on....i need to flash bios again
        board number VIUX1 NM-A091 REV:1.0...
        02-07-2024, 01:57 AM
      • Ryan.man
        by Ryan.man
        02-04-2025, 12:23 PM
