Sharp Aquos 46 - j655 k3704 help plz
  • basman2014
    • Oct 2014
    • 5
    • Libya
    I have sharp aquos LCD Tv with brand no. ( Lc-46a65m ) it turned back to stand by with red light works only for few seconds with dark screen,
    days later after searching , I found that the transistors (j655 and k3704 ) had a short on board ,, but unfortunately the same transistors aren`t available in libyan market , and due to countery condition those days , I couldn`t also buy it from outside or online market on internet.
    So, i decided to buy alternative transistor for bad luck tell now I couldn`t find the same values of those transistors the only near values are :|
    17a -100v ( old transistor value is 12a 100v)
    55a -60v ( old transistor value is 45a 60v )
    but sadly screen didn`t work and also short happend on (55a-60v) transistor with bad smell comes from it .
    So, if u kindly help me to find alternative transistor or any another solution to fix these problem
  • basman2014
    • Oct 2014
    • 5
    • Libya
    Re: Sharp Aquos 46 - j655 k3704 help plz
    Waiting for ur replays
      Less than 45 minutes to a bump? Leave it a little longer.
      Pictures of the parts and circuit board layout?
      Details of tests so far - voltage measurements, part replacements, service guide procedures checked?
      Without that info don't expect any useful suggestions...
      • Alastair E
        Chief Womble
        • Mar 2013
        • 1963
        • U.K.
        2SJ655 and 2SK3704 are MOSFETS. Can you take pic of the board where these are mounted so we can see what they are doing.
        I'm just guessing that they are on the backlight-board or PSU supplying the backlight circuit....
        TELEFIX
        • basman2014
          • Oct 2014
          • 5
          • Libya
          Thanks for both of u for ur fast response
          • basman2014
            • Oct 2014
            • 5
            • Libya
            I found 15 a 100 v mosfeet and 50 a 60 v when I tried them they become hot and TV going back to stand by situation
            • scubacamper
              Sharp Aquos LC-70C6400U Half Screen Dark
              by scubacamper
              I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
              Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
              when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
              05-03-2025, 12:19 PM
            • sefoster
              Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
              by sefoster
              I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
              11-20-2022, 09:29 AM
            • jonah1024
              Sharp Aquos LC-40UG7252E LCD TV burn in?
              by jonah1024
              Hello!
              I'm a few days old into this TV screens repair universe so please bear with me.
              Recently, and all of a sudden my 40” 4K Sharp Aquos LCD TV turned on with colors all smudged in some places on the screen that remain like that even without any kind of video source. I do have image but the colors are smudged/tinted/ washed out in patches as per defects. This to me looks similar to burn in but I’m shore this is not an OLED.
              - I did the classic unplug and hold power button to discharge the caps but it didn't help.
              - I did a factory reset as well...
              07-16-2024, 04:23 AM
            • klassic
              Sharp Aquos LC-60LE635E three blinks
              by klassic
              Hi community,
              I will describe my problem with a TV in those short following terms to be the most precise :
              What i have :
              power board DPS-162KP-1
              main logic board QPWBXF733WJN2
              symptoms :
              white led light logo at startup,
              after 2 minutes, blinking 3 times a row, repeating
              no backlight (and apparently no picture, checked panel with flashlight)
              no startup sound
              powerboard investigations :
              1-2 PNL : 0v
              3-4 GND
              5-6-7-8 UR : 13.15v
              9-10-11-12...
              10-24-2023, 01:39 PM
            • foxyUK
              Sharp Aquos LC-32LE600E, No 12v as no PNL_POW
              by foxyUK
              Can anyone help me diagnose this? Almost not worth bothering with, but it has 'sentimental value' for the owner. I'm no TV technician, but dabble a bit.
              The TV has standby power but no reaction at all to switching on or reboot steps, No flashing lights or response to menu button. All voltages on the power board are correct apart from missing voltage on pin 12 of CN7003.
              There is 13 v on U7053 but no 3v signal to switch it on. I don't really understand whether the 3v should come from U7401 in the standby control area, or (as suggested elsewhere) from the mainboard via pin 12....
              10-22-2024, 10:27 AM
