Vizio e241-a1 not powering up
  • FocusMiah
    • Oct 2014
    • 6
    Hello all! Thanks for reading.
    I received the tv as it was not working. When i first got the tv the power light would come on white.
    I opened it up and started checking regulators. All seemed fine but the two in red boxes. They are both the same 1084 regulator. The one on the left read from left to right .24, 1.47, 5.08 and the one on the right read 2.06, 3.31, 5.08.
    After having the TV plugged in for a half hour or so the reading from all the regulators started to surge. For example if i held the multimeter an anything that was 5.08 i would hear a very faint hum and the power would drop to 4.2ish for a split second and come right back up. Same for any point that showed it had power.
    Re: Vizio e241-a1 not powering up
    5.08V is the standby power supply that feeds those two regulators, the output voltage readings of those two regulators are correct. It sounds like you are having standby power suppl problem or the main board is drawing too much power from the standby power supply.
    Please up load the pictures of the whole back side of the TV so we can see all the boards.
    • FocusMiah
      • Oct 2014
      • 6
      Here are the rest of the boards
        Please up load pictures using 'GO AVANCED'
        No pictures of the back side of the TV so we can see how all the boards are connected together?
        • FocusMiah
          • Oct 2014
          • 6
          Sorry misunderstood!
          • FocusMiah
            • Oct 2014
            • 6
            Also if i disconnect the power supply board from the main board. The power no longer surges on the power board, and all the pins from the connector stay steady at 5.08 and 15.86. When its plugged back into the main board the surging starts again and the regulator i have in the square to the left gets extremely hot.
            • FocusMiah
              • Oct 2014
              • 6
              Where would be a good place to start to learn more about circuit boards, components, and how they work or test them.
              Books or websites.
              • Mike's TV Repair
                • May 2014
                • 3
                Did you find a fix for this TV? I have 2 with the same problem..
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  If the fault is identical and the regulators are geting hot and the voltage is dropping then I can only think of two possibilities.
                  1. The current required by the main board is excessive.
                  2. There is considerable voltage ripple on the supply and the capacitors/diodes on the power supply need to be checked.
                    MSI Prestige P65 Creator-1084 Notebook P Specification for Upgrade or Repair
                    This specification for the MSI Prestige P65 Creator-1084 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 Creator-1084 boardview and P65 Creator-1084 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                    09-06-2024, 11:32 AM
                  • SS454
                    vizio e650i-a2 backlight flashes then turns off
                    by SS454
                    vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                    panel: au optronics T650HVN05.4
                    72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                    link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                    Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                    https://www.shopjimmy.com/vizio-56-0...-power-supply/
                    Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                    08-20-2020, 03:57 PM
                  • mrtek
                    Vizio M65-C1
                    by mrtek
                    Hi.
                    picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                    When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                    This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                    07-14-2025, 07:28 PM
                  • yuii
                    ThinkPad W530 - faulty CPU regulators?
                    by yuii
                    Hello
                    I've got two W530 boards, one with K1000M and one with K2000M graphics card. The first one had an issue of turning off under heavy CPU load after about 30 minutes or in idle. GPU load wasn't causing it to shut down. Trying to turn it back on would only make the power LED to come up for about 2 seconds without fan spin or thinklight flash, and that's it. It also wasn't charging the battery after it died.
                    Gently pressing the laptop in left upper corner would fix this problem for a couple of days.
                    The latter is completely dead and has the same 2-second power blink, nevermind...
                    11-01-2023, 02:59 AM
