Logik L32HE13 Led Tv
+ More Options
Posts
  • danjcarr1
    • Jul 2012
    • 35
    • Uk
    Hi all I have a faulty Logik Tv model Number is L32HE13.
    Set was powering to a red standby but no further.
    PSU tested fine.
    I got a set with a smashed screen and it had the same psu but an ever so slightly different main board.
    I fitted the main board and the set fires up and works however When turned off (to standby) the screen fades away. Also when first powered on from mains power the backlight lights when in standby.
    Does anyone know how to access the service menu on a Logik tv???
    Regards Dan
  • danjcarr1
    • Jul 2012
    • 35
    • Uk
    Re: Logik L32HE13 Led Tv
    gif hosting
    • danjcarr1
      • Jul 2012
      • 35
      • Uk
      Bottom main board is the faulty original and top (connected board) is the replacement
      • Dani_2024
        by Dani_2024
        10-28-2024, 05:06 PM
      • ygorsan
        by ygorsan
        🧩 Problem Summary:
        • I
        07-28-2025, 08:34 AM
      • jb_Bak
        by jb_Bak
        CN6401
        Pin 01 NC
        Pin 02 NC
        Pin 03 "BL_ON": 0V
        Pin 04 "N/C"
        Pin 05 "STBY 3.3V": 3.5V
        Pin 06 "GND": N/C
        Pin 07 "AC_OFF"...
        09-27-2021, 04:52 PM
      • JDC
        by JDC
        ONN 100012588
        Long answer:
        07-15-2022, 07:39 AM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
