LG 60PV250 - shorted ZSUS EBR73561701
  • digitalscorpion
    • Mar 2012
    • 37
    Narrowed my issue down to this board (ZSUS EBR73561701). Vs is shorted to GND. Unable to determine fault. Been trying to somehow break/split the circuit in half to see where my short is coming from.
    Visual is OK. Solder is OK. Caps are OK. Fuses OK.
    this board is sold out everywhere so I am trying to save this board.
    Any possible way to troubleshoot this further without removing the middle bank of fets and big heatsink?
    Re: LG 60PV250 - shorted ZSUS EBR73561701
    A good way of finding a fault like this is to check the DRAIN-GATE and SOURCE-GATE of all transistors. In many cases when transistors fail these junctions will also get shorted.
    • digitalscorpion
      • Mar 2012
      • 37
      If I am doing it correctly, they are all shorted. I think something else is crossing these lines. Center black heatsink block with all attached components are linked together. Could they all have gone at once? Trying to avoid lifting this section off and kill this board completely.
      And of course service manual has no schematics or part listings. :/
      • tw2005
        • Oct 2011
        • 6458
        Maybe try here, check if they actually have stock. I just tried an order for a 1000 units and it added to cart so that seemed sus, probably not live data.
        Can but try
        http://www.buypanasonicparts.com/ite...nsert_Pcb_Assy
          I think you are testing across drain and source. Only a few transistors will probably be actually shorted across drain-gate or gate-source.
          • cliff_hootarski
            • Jul 2006
            • 411
            Perhaps, the transistors are in parallel, so if one shows shorted, they all will.
            • digitalscorpion
              • Mar 2012
              • 37
              tom66 - all pin configurations, shorted.
              Would that mean in parallel and one is causing my issue? No other way except removing the whole block of them?.. not easily accesible to do just one.
              • reessi
                Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
                by reessi
                Hello:
                I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
                I started on the ACER:
                Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
                All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
                I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
                10-29-2024, 11:31 AM
              • Yanleb
                Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
                by Yanleb
                Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
                I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
                D608, good
                D618 RF101L4S, good (See warning 1 below)
                D619 RF101L4S, good (See warning 1 below)
                D865 RF101L4S, shorted (See warning 1 below)
                IC464 Inverter HA MC74HC1G14, shorted...
                03-09-2020, 12:00 AM
              • modtool
                HP Victus 15-FA1025NL , board DAG3PAMB8D0 REV:D, shorted CPU DrMOS and n-mos
                by modtool
                Hi to all,
                the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
                I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
                I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts...
                04-01-2025, 08:22 AM
              • BalkanBoy
                Dead Razer Blade 14 2022, shorted CPU?
                by BalkanBoy
                today I got Razer Blade 14, Ryzen 9 6900HX and RTX 3070Ti.
                Laptop was completely dead. I found shorted CPU VRM mosfet, shorted 19V mosfet and blown battery fuse.
                I replaced it all, but still on CPU coil where mosfet was shorted I got very low resistance, near 0 ohms. On other CPU coils I got around 3 ohms.
                Laptop now raises voltage on whole board, but still nothing comes on the screen. CPU gets 0.7V on all coils except the shorted one. CPU gets only slightly hot, below 40 C.
                I removed coil and injected 0.7V, it draw around...
                09-27-2024, 12:44 PM
              • barry101
                Apple 820-3662 VCore shorted to ground.
                by barry101
                Hi, Would appreciate some help.
                I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
                Get charger light but no fan spin or chime. No liquid damage.
                Found PPBUS and VCORE both shorted to ground. Other rails were ok.
                Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
                With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
                Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
                06-24-2025, 07:34 AM
