Samsung LE40A65A1FXXA
  • vinceroger69
    • Mar 2012
    • 6714
    Hi just visited a friend who has a problem with a samsung i have enclosed pictures i tried twisting the screen surround made no difference.I did try the tv on the wi console and it has sound the picture just has loads of lines on it etc on certain inputs you do get a white cloudy screen with times the lines get less and you can see the no signal box/menu/hdmi writing etc.I am thinking tab bond issue whats your thoughts.
    Re: Samsung LE40A65A1FXXA
    Defective LCD panel. may be possible to shim the tab bonds. I have one doing similar when very cold.
    • vinceroger69
      • Mar 2012
      • 6714
      cheers tom are the tabs on these top/bottom or side? just curiosity ive just asked my friend the back ground of the tv he got it from a mate it went like this when they was cleaning the screen so as you say probably fluid on tabs or the pcb to tabs? if on the bottom. tom in the past you recomended to me some solder braid from cpc you use can you send a link im just placing a order cheers again for your input.
        Tabs are on the top.
        Cleaning fluid unlikely to cause this effect.
        • vinceroger69
          • Mar 2012
          • 6714
          Just been told by my friend they left the set on all night still had lines and bad picture, he switched the tv off to move it and then he switched it back on the pictures perfect? and hes been watching it for hours now with no issues at all.I will try the shims on the tab bonds and see what happens from cold i guess.
          • senndogg
            • Dec 2011
            • 383
            • Albania
            I am impressed how frequent we are seeing the LxxxA65x panel fail. I have had more than 10 cases this year in my very modest workshop.
            • vinceroger69
              • Mar 2012
              • 6714
              did you manage to do the tab bond fix on any? or didnt you bother trying.
              • senndogg
                • Dec 2011
                • 383
                • Albania
                The very last one which is still in my workshop for 3 days is beyond repairable.
                Had success only with ones which bonds are VISIBLY disconnected from the upper pcb. Any other could be just a temporary fix.
                • vinceroger69
                  • Mar 2012
                  • 6714
                  yes thats what i said to my friend whatever it will only be a tempory fix he got the tv for nothing so nothing lost money wise. I may have a look see if i can shim the bonds etc as its only a tv for a bedroom etc that wont get moved much if any.
                    09-07-2024, 05:50 AM
                  • Falki
                    Colorful LCD Vertical Lines on Samsung ue55es8090
                    by Falki
                    Hello there, ive recently found an older 55inch Samsung SmartTV.
                    A similar issue has been posted as well but also with no actual response ...
                    08-12-2025, 04:19 AM
                  • Rubenlily
                    Samsung QE50Q67TAU - horizontal lines
                    by Rubenlily
                    First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
                    I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
                    I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
                    I'm no expert but I've done the tape...
                    08-16-2023, 01:12 PM
                  • jeyoung12
                    Samsung QN50Q60t lines on screen
                    by jeyoung12
                    Hi all
                    I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
                    My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
                    This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
                    It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
                    So....i don't know what end of the C ribbon to work with...
                    02-26-2024, 10:38 AM
                    09-06-2024, 11:40 PM
