HITACHI P50TP01E Y-Buffers/Sus problem
    replied
    Re: HITACHI P50TP01E Y-Buffers/Sus problem
    USB scopes are generally a bit rubbish.
    You can do well just with a good, used analog scope with at least 20MHz of analog bandwidth.
    Such examples are often available for under $50 on trading sites and eBay.
    Dual channel, 400V input minimum.
  • reaper57
    replied
    Maybe, ICs just kept frying every time I turned it on. Turns out the Vscan was bad, but the owner didn't want me to continue with my troubleshooting. I was really hopping to fix this TV, but oh well.
    On the other hand I realized that most of the FETs on the Y-sus board are MOSFETs... (I know it should be obvious, but I guess I just didn't really think about it). So, I guess the oscilloscope tom was talking about was for testing those. It still sounds like a good idea to get one, but I'm not really sure about which one. I prefer a USB one, but I hear that people don't like them very much and prefer standalone ones. Do you think that this is a good one and if not what do you recommend?
    http://www.ebay.com/itm/SainSmart-DD...item461487cb94
  • Shinju
    replied
    Are the buffers good?
  • reaper57
    replied
    Well guys, I forgot to mention that the tv wasn't mine, and the owner no longer wants it fixed. I told them that I had some progress, but I guess the repair was going to cost him more than this whole 8 year old tv so he just didn't want to bother with it anymore.
    Anyways, thanks to everyone who tried to help me, especially tom66.
    I guess it's back to my other projects for me. :P
  • reaper57
    replied
    Originally posted by tom66
    Hmm, looked like one but it isn't.
    Can you get a clear close up photo of the whole Y-sus... if necessary split it into several images to ensure they are clear and in focus.
    I think I found the transformer that you are talking about (it should be the first attachment). There is also one similar to this one on the top of the board, I took a picture of it as well. I've also attached pictures of the Y and X-sus boards.
    replied
  • reaper57
    replied
    There appears to be a small white transformer near the bottom of the Y-sus / Y-drive board, can you get a picture of it?
    https://www.badcaps.net/forum/attach...8&d=1412248465
    The pictures are in the attachments and the model of the samsung tv I scraped is PS-50Q97HD.
    replied
  • reaper57
    replied
    Do you have an oscilloscope available?
    No, unfortunately I do not, I have a capacitance meter, though. But do you think that the caps have gotten so bad that they are messing up the voltage this bad (or is the oscilloscope for testing something else, sorry I'm new to these types of devices)?
    P.S. I scraped a 50" Samsung plasma with a cracked panel a day ago (I don't have it at home, and I don't remember the model, but I will check it tomorrow and post it here). The boards aren't the same, but some of the components should be the same, and if needed I could swap FETs, caps, ICs etc, between the TVs.
    replied
  • reaper57
    replied
    Do you (or anyone) have any ideas about what could be causing unstable the voltage? Also can someone, kindly explain to me, how to test the Y-sus, X-sus and anything else that might be the the reason for my problem? I have no problem with desoldering MOSFETs/FETs and testing each and everyone of them. Btw huge thanks for the help so far.
  • reaper57
    replied
    So that was DC volts, red on red circle, black on black circle? If so, your Vscan supply has a serious issue... this is what is destroying your buffer boards, I suspect.
    Yes, that is correct negative on black positive on red. Also after removing the last chip the picture ot the top of the screen (the only one that was normal) started vibrating, but I suspect that might be because of the missing components from the buffers, and maybe this is the same reason that the voltage isn't stable? All of the cables going into the Y-sus are comming from the X-sus, so that probably means that the problem could be in the X-sus, right?
    When changing the caps on the power supply there were two 270uf caps and one of the 270uf caps I had, when measured showed only 245uf so I put that in with a 330uf cap that showed 290uf. I think that they are filtering the same current so the effect should be the same as having two caps at ~260-270uf right?
    I've marked the changed caps with red.
    replied
  • reaper57
    replied
    Ok, I did what you asked me, two times. The first time the Vsc was 125v and went up to 212v when picture appeared then down to 180v when the picture changed (probably a message appeared, it was on AV so it was searching for signal I guess the message was about that, but for me it was just white lines), then it went up to 212v again and 180v when white lines appeared in the middle of the screen (a no signal found message I think)
    The second time, 100v at start, 90v for less than a second, 212v on the first white lines, then 180v, then 105v for 2s and then 180v at the second white lines.
    The voltages that appeared only for a little could be because the tv starts with no indication about which input it's set to then is says AV at the top and then it disappears.
    replied
    See here
  • reaper57
    replied
    DC wrt to the floating ground point (buffer ground plane), but AC wrt to the chassis.
    My multimeter was set to DC and started making buzzing noise with the negative probe touching the chassis. Can you help me locate a place to get the floating ground point from? Or will using the chassis work?
    replied
  • reaper57
    replied
    Well, you will have to be quicker next time... something is clearly amiss with the Vscan supply as I can't think of anything else that would cause that.
    Well I did short it by mistake... It was when checking the Vs at the power supply port, there was a flash, but the tv didn't even turn off. And it was before the tv even gave any picture, it was before I started removing chips and after I removed one of the buffers. And after a few restarts the tv kept giving me the same black screen as before. My friend told me that I probably just drained the caps.
    I just desoldered the bad chip and am about to clean the solder. And a quick question the current at R812 is DC right?
    replied
  • reaper57
    replied
    P.S. Again on the lower buffer.
  • ugamazing
    Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
    by ugamazing
    I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
    08-31-2022, 07:34 AM
  • howardc64
    by howardc64
    07-24-2025, 05:17 PM
  • kdaniel
    Hitachi 58HK6100U - Horizontal Lines (Bottom third of the screen)
    by kdaniel
    As stated by the person I collected the TV from, it just stopped working overnight. However, I still gave it a go to try and repair it.
    There is a thread on the same TV but with slightly different issues where they had to tape connection points on the ribbon cable, so I want to see if this is repairable by any chance.
    After bringing it home and plugging it in, the TV turned on with its backlight working but had no picture. After removing the back cover, the first thing I tried is to unplug one of the ribbon cables and the situation is as follows.
    Left...
    11-16-2022, 09:23 AM
  • Syseng
    Lenovo P14s Gen 5 SVP unlock
    by Syseng
    This sums up discussion related to Lenovo P14s Gen5 in this thread. Credits go to Sbaro and especially Maxpower3. The locked dump is attached.
    The device is based on NM-F871 motherboard with Nuvoton NPCK397 series controller. The motherboard also contains three BIOS chips: two different Winbond chips for main BIOS and external EC flash, and also a Gigadevice chip which purpose I do not know. The password information is contained directly in controller and thus can be manipulated by reprogramming it, so reprogramming BIOS chips is technically not required, however you may wish to make...
    06-22-2025, 07:44 AM
  • Stanley1843
    by Stanley1843
    06-29-2024, 11:54 AM
