Hello everyone, I have a problem with one of our schools plasma, it seem to have a red screen as if the blacks are now red, i saw it in a similar post, and it looks like same problem, I have opened it up, fans are all working and clean, checked as much connectors as possible, could it be on it way out, the picture looks red and a little patchy. any help would be great.
Panasonic TH-42PH9BK red screen
Re: Panasonic TH-42PH9BK red screen
Could you show a picture of the exact fault? There are two possibilities - most likely loose LVDS (red multistranded cable going to the "D" board.) Second most likely is bad "SS" board which can cause a red tint to the image.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search. -
thanks tom, i had the plasma on a table face down, i hope the photo helps, i took of the multi red cable and reseated it , but still no joy. Prob goosedAttached Filesif you find these attachements useful please consider making a small donation to the site
I still have the same issue, since i put it back together, it has flickered back to normal a few time, staying for 5 secs to 1 minute, I have uploaded another photo, the menu controls look normal. any help would be greatAttached Filesif you find these attachements useful please consider making a small donation to the site
Locate and clean both ends of the LVDS Cable from A Board to D Board with WD/40.TELEFIX
PLEASE DO NOT EMAIL ME PRIVATELY FOR REPAIR ADVICE. QUESTIONS BELONG ON THE FORUM!Comment
thank you so much for all your help, got the problem fixed so really impressed with the service and knowledge of all the people that help. I removed all the cables and clean them all with wd 40, put them back together and then left it for a few hours until residue dried up, powered up and its been working now for 1 week. Great job guys thank you very much.Comment
by Ryan.manHello everybody! Posting this in hopes somebody has some expertise that leads to a clear path of troubleshooting that saves me a lot of time!
This time the original cable broke too close to the screen, it can't be fixed without tearing the screen... -
by ChrissygizmoHi all, I’ve got a problem I hope someone can help me fixi.
I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...01-11-2025, 03:18 PM -
by AlicatHello,
Stopped by this site trying to fix my parents Panasonic Plasma TV.
Model number is TH-50PZ85U
Power comes on and the red power light stays on solid.
Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
I also hear a few clicks.
I also think my parents said there was a thunderstorm and the TV failed after that.
Section 6 in the service manual talks about power and no screen,...10-30-2024, 10:09 AM -
by reformattJust had a customer bring in a M2 MBA A2681 that had had a screen replacement in April at another repairer. Since then, she has been getting intermittent kernel panics. It's an aftermarket screen, and of course it fails in diagnostics as the calibration hasn't been done. The error in the panic log is "No device added after powering on the rails".
It seems the original repairer has swapped the board and the screen to other MAC's, and said that it isn't a screen issue. From what I understand, by doing a quick search on Google, this is in fact a screen issue. The panic relates...07-31-2025, 08:37 PM -
by smic717394Hi,
I have a iphone XS that came in for a screen replacement, the screen was badly cracked, and inside missing scues, on the back of the screen still the blue protector, the screen was a LCD. So we replaced the screen and all good, installed the screen and we noticed that pressing the screen with a bit of force but not excessive, the phone dies. After plugging the charger it turns back on, but again if you press it it dies. I open the phone again, and I can't see anything major, with the phone open, if I press on the logic board, battery, charging board, or even putting pressure on... - Loading...
