Philips 42PF7320A/37 power supply - quick question?
  • homer308
    • Oct 2014
    'Evening all!
    First post to ask some assistance and hopefully a simple question - I had the C8059/C8060 cap problem on my power supply after the set died and yielded the 7 code.
    I've replaced the caps per the many threads about this problem; problem is I still have the 7 code flashing at me.
    My question is:
    If I plug in ONLY the power connector on the power supply board, leaving all the other connectors disconnected; and then plug the set in, should the two green LED's stay lit or will they cycle off? Just looking for a quick way to determine if the power supply is operating properly.
    I'm going to dig up the service manual for this chassis having found links to it here on badcaps; however, from what I have researched there is no schematic for the power supply itself - can anyone direct me to what voltages I should be seeing at each of the connectors?
    Thanks much and have a great evening!
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
    03-31-2024, 02:12 PM
    07-01-2024, 06:34 AM
  • JimBanville
    Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
    by JimBanville
    The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
    I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
    09-13-2023, 07:21 AM
  • CMCM
    Russound CA4 Power Supply Repair
    by CMCM
    Hello Everybody,
    Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
    Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
    The outputs marked 12v and 20v are all measuring only 1v.
    The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
    The capacitors physically look clean (no bludgesor leaks) and...
    07-03-2025, 01:12 PM
