Dell monitor model se198wfpf
  • Vivi
    Banned
    • Sep 2014
    • 101
    Does anyone know why the dell monitor MODEL (Dell monitor model se198wfpf) does not work? I mean the brightness and contrast buttons work, but the menu button does not. And the button is not broken or sticky or anything.
  • keepread
    Dell monitor PSU vs Dell laptop PSU
    by keepread
    Hi there!
    Someone gave me their old monitor, it's Dell S2715ht.
    The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
    Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
    10-30-2025, 04:45 PM
  • angelos
    Dell LED Monitor Model SE2717H
    by angelos
    Hi Guys, i just have a question that is probably easy to answer if you have experience on such matters.
    My Dell Monitors screen was damaged by lightning via the HDMI port. The monitor does come on but cannot display HDMI or VGA image. it says no signal.
    I have ordered the board on Aliexpress. They say 100% working. Don't trust. it.
    My question is, after installing the new board, is there anything else I need to do in order to make this board work. I know on some TV's you need to load software on the board to make it work but this is a monitor or even having to go into service...
    03-25-2024, 04:12 AM
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
  • DanPoka
    Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
    by DanPoka
    I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
    Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
    This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
    02-15-2025, 05:05 AM
    by momaka
    03-15-2023, 10:17 PM
