samsung hpn5039 ax50p3 doesn't power up.
+ More Options
Posts
  • Bob Neely
    • Oct 2013
    • 41
    Greeting,
    I have this TV that will not power up.
    I took the back off and check for the 5vdc stby voltage on the power supply at connector CN804 and the test point and I am getting 2.9vdc. The PS ON voltage is 1.6vdc on connector CN802.
    When I use the power button on the side of the set I hear a click then a short fizzle sound next to connector CN804. When the TV is originally plugged in there is a red led on the front. When I push the power button it blinks 5 times then it goes out.
    Here are some pics of the power supply.
    Any help would be appreciated.
  • Bob Neely
    • Oct 2013
    • 41
    Re: samsung hpn5039 ax50p3 doesn't power up.
    Can anybody help. I would really like to get this off my table.
    • Bob Neely
      • Oct 2013
      • 41
      Changed power supply. Get stby 5vdc getting ps on voltage.
      Checked
      V5D- 5.3vdc .... 2.1vdc
      VG- 15vdc.... 14.8 vdc
      Vscan- 95vdc..... 78vdc
      Vs- 88vdc..... No volts
      Vest....126vdc .... No volts
      Ve..... 115vdc.... No volts
      Va...... 76vdc..... 78vdc
      Can anybody help?
      • Alastair E
        Chief Womble
        • Mar 2013
        • 1963
        • U.K.
        You have no Vs.....
        Check for shorts on the Vs line. Try running with first Y-SUS disconnected from PSU, then X-SUS disconnected from PSU--See if the voltage returns at the PSU with either disconnected.
        If not, then you probably have a faulty replacement PSU.
        TELEFIX
        • Bob Neely
          • Oct 2013
          • 41
          Thanks Alastair E.
          I did disconnected the X-sus and Y-sus boards after the post. No change. I guess the PSU is bad. I will look for the short on the VS line.
          Anybody know where I can get the schematic for this unit?
          • PantherDave
            by PantherDave
            Hi all!
            05-29-2024, 02:01 PM
          • GLISIT
            by GLISIT
            01-16-2025, 02:29 PM
          • mrtek
            Samsung UN43NU6950FXZA No power
            by mrtek
            Hi
            Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
            Main fuse = OK
            Back light LED = OK. Power them with aux power source
            LED output = OK 156V
            I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
            Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on...
            07-20-2025, 08:06 PM
          • hill01
            Samsung UE75MU7009TXZG Endless Power Cycle
            by hill01
            Hi everyone and thanks in advance for any help I might get here
            My Samsung TV is about 4 years old. The exact model number is UE75MU7009TXZG.
            About half a year ago I started seeing occasional green frames pop up while watching movies. I mean literally green frames. Not the image turning green, but the entire screen turning green for a split second. This happened maybe once or twice during a 2 hour movie. So no big deal, but clearly something was not quite right.
            Since a few days, the TV won't turn...
            11-17-2021, 02:52 PM
