Maxent 50" Plasma problem
  • smuddge
    • Feb 2012
    • 96
    I have a Maxent 50" plasma model MX-50HPT51
    No display black screen power light turns green from standby but on the ctrl board underneath the main board I had a flashing green light.
    started by checking fuses and I found all were fine except the one on the ysus which was then replaced.
    powered it on again and the power supply made a strange buzzing sound not loud or very long and still no display. the green flashing light didn't flash on the ctrl board anymore however still no display. the power supply has a small riser board on it and it has an led that flashes green 8 times then repeats.
    the power supply is model: LJ44-00136A board number PS-50W1-STD
    I have not measured any voltages as I am still not very good with that although I am learning.
    I am thinking either bad ysus or buffer board or bad power supply or all.
    not sure where to go from here.
    any help would be appreciated.
    thanks in advance.
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • m1ch43lzm
    by m1ch43lzm
    05-12-2025, 08:37 PM
  • howardc64
    by howardc64
    07-24-2025, 05:17 PM
  • Cooperr
    Samsung 59" plasma PN59D550C1F seeking advice on mystery power board issue
    by Cooperr
    I picked up this TV from Facebook Marketplace, original owner described it as "screen went black after a pop" and I hoped to see an obvious fuse or cap to replace. Doesn't seem to be the case, but my experience and electrical knowledge are kind of limited for this.
    The power board (BN44-00445A, see attached) turns on and Vs and Va seem to momentarily have power, then they steadily drain to zero over a minute or two as if they're only getting power from capacitors. I've been measuring Vs and Va from the test pads, with and without the other boards connected to the power board...
    10-21-2025, 01:11 PM
  • stecos
    Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
    by stecos
    Hi everyone!
    I happened several times, in the search for help from the web, to consult this very interesting forum.
    So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
    Having said that I come to the gist of my post on the forum as the title suggests.
    For my passion for technology I'm now collecting several...
    11-28-2022, 11:39 AM
