Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture on half left screen but always with the vertical line….did I finish to break the panel when I pick up it from her house? Can I fix it?
LG 49uf695v vertical coloured lines
It's not so important in a closet or not, if is at open air, more or less, it damages itself, modern tv sets are very fragile, there is no efficent cure as i have fully tested until now, you can only try heating with hair dryer the panel fpc (flex tabs) until some oxy goes away.. i do not see horizontal lines..Comment
dont use hair dryer or any source of hot air.. its wrong from some one dont know and dont have the right tool.... buy T silicon Iron for COF and apply to the COF near to line area... this could help some time but not always as need to renew the COF pasta.Comment
thanks for the ansswer what temperature i have to use and i have to add flux? because if i buy the t iron i ll buy also the flux or something i need let me know thaks, and i have to do with the tv on or with the tv off?Comment
thanks tried wirh the hair phone but didt change...i thik i ll try with. something more hot....in the other way i have to trash itIt's not so important in a closet or not, if is at open air, more or less, it damages itself, modern tv sets are very fragile, there is no efficent cure as i have fully tested until now, you can only try heating with hair dryer the panel fpc (flex tabs) until some oxy goes away.. i do not see horizontal lines..Comment
why you asked this and my warning didn't took it,, now you pushed air between COF and Glass , nothings you can, only COF vacuum Stamp machine can renew the defect COF soldering... search at your country service they have the vacuum stamp machine.Comment
by Stanley1843Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
tried blocking LC lines too, but same results
is it lcd panel issue or tcon board issue?... -
by kcaHello all ~
I got the display to work by taping off several traces of the right-hand side ribbon cable on the TCON that leads from TCON to PANEL. However, despite dozens and dozens of attempts to find the right combination / range of traces taped... -
by gpo23Hello,
i order a t-con because i had bad colors on my SONY KDL-40V3000 :
With the new t-con the color are good but there are vertical lines on all the screen :
I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
Is there a way to fix the vertical lines on the new t-con ?
Thank you for your help
gpo23... - Loading...
