LG 50PJ550 adjusting volume by itself
  • Stingos1
    • Jul 2014
    • 7
    • Uk
    Hi folks onto my 3rd LG fixed 2 so far with the help posted in these forums
    So here goes as title states volume intermittently goes all the way down or up picked the set up cheap knowing there was an issue but could not find anything when googling prior to purchase,
    Guy said it just appears on screen now and again
    When got it home volume was switched off he must of been going through a amp sepreratley turned sound back on, left it on about 2 hours then it started to turn itself all the way down with led constantly flashing at zero.
    Pressed exit on remote then adjusted volume accordingly, then turned volume up to about 75 and it turned itself back down,
    Then turned itself back up again.
    Remote batteries disconnected on both.tv still trying to cycle volume up or down
    I have two lg remotes so the problem is defiantly not the remotes.
    Where do I go from here cheers.
  • SteveNielsen
    Retired Tech
    • Jun 2012
    • 2327
    Re: LG 50PJ550 adjusting volume by itself
    Maybe a sticky/dirty front panel vol control?
    • Stingos1
      • Jul 2014
      • 7
      • Uk
      The panel controls are touch control only I believe no buttons
        Still can be dirt causing issues with them.
        • Stingos1
          • Jul 2014
          • 7
          • Uk
          So strip back off then what.?
          • SteveNielsen
            Retired Tech
            • Jun 2012
            • 2327
            I don't know that it would help but there's a firmware update released last year:
            http://www.lg.com/uk/support-product/lg-50PJ550
            • Shinju
              • Mar 2014
              • 1239
              this is a bad RF Function board, I just replaced one on a Samsung doing the exact same thing.
              • Stingos1
                • Jul 2014
                • 7
                • Uk
                Software version
                V03.28.00
                Update software or start stripping it???
                • Neelix
                  • Oct 2013
                  • 145
                  • South Africa
                  That's a common problem caused by faulty capacitive switches on the control/IR board. The board would need to be replaced. You should be able to get a replacement board from your local LG spares agent
                  • karthur
                    Vizio D65x-G4 Volume changes on its own
                    by karthur
                    On this Vizio D65x, the volume will change on its own. I don't mean like during commercials where the volume will increase. I mean its like the (+) volume button on the remote is pressed and the actual volume dialog is displayed on the screen going up. It will do this, then the volume may start going down. It might go all the way to "0"or it might stop at a different number, then start going back up. The whole time its doing this, the volume dialog is shown on the screen.
                    It wont do it until it has been "ON" for 20 or 30 minutes, so it does seem to be heat related....
                    06-05-2025, 08:13 AM
                  • crackedprint
                    Sony HCD-HX80R Amplifier Volume Control Problem
                    by crackedprint
                    I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
                    I have tried a Cold Reset as per the service manual.
                    I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
                    I have looked all the way through the service manual and tried many online...
                    01-21-2025, 12:18 PM
                  • BigOof
                    Marantz SR5007 popping on volume change and mute in Direct Mode
                    by BigOof
                    I bought a used Marantz SR5007 and it's giving me some issues that I can't seem to really place. It functions well in most settings, ARC mostly works, it has no issues driving my speakers in any of the digital input modes, but I'm having issues running analog inputs in direct or pure direct mode. For some reason in this mode there's distortion for every volume increment I give it, but once the volume is stable it has no issues. Muting creates a loud pop, switching to another source also causes a pop and so does turning off the amp in that mode. Again, no issue in the digital modes....
                    12-12-2024, 06:15 AM
                  • Storyteller12
                    Samsung Soundbar Q900T Cuts Off if Volume above 30
                    by Storyteller12
                    I have this soundbar and when I turn it on it works until I turn the volume above 30.
                    Then the display show “PROT” protection and shuts off.
                    I can turn it right back on and it works until volume hits 30 again.
                    There is a little static on the surround speakers so I unplugged them but still have same problem. I tried unplugging all speakers also and when volume goes above 30 it shuts off.
                    I can turn the volume above 30 if nothing is playing but as soon as I play something it shuts off.
                    It will play fine for hours with volume...
                    03-21-2023, 12:31 PM
                  • peter99
                    HP 245 laptop not charging when turned on
                    by peter99
                    helo everry body!!!
                    My laptop HP 245 AMD 14-FP5-6L -GDDR5X2 has a battery charging circuit error:
                    - If not power on, battery charge ok.
                    - if i turn on the power, not charging the battery ( the battery charging indicator light, from yellow to white)
                    The laptop only charges when not turned on. I have changed the battery and charger, but the situation remains unchanged.
                    I replaced the BQ 25A charging IC but the device only charges when not turned on.
                    everyone please help me with solution, what should i do ?
                    thanks a lot !!!!!...
                    04-04-2025, 07:35 AM
