Toshiba 40FT2U Weird colored screen
  • zdsh07p9
    • Nov 2013
    • 155
    Okay so the Main board was bad (TV wouldn't start, no standby light) and I ordered a mainboard + put it in and now it starts but the colors are weird on the TV. They're almost like a weird opposite - don't know how to describe but pictures are below. I thought it was the T con board but when I got the replacement in Today it has the same colors. The two mainboards have different Revisions on them but look exactly the same. the one I pulled out (bad) was revision 1A, the good one is revision 1D
  • hardbox
    • Sep 2013
    • 22
    Re: Toshiba 40FT2U Weird colored screen
    Hi there,
    I got exactly the same problem with my Toshiba 40FT2U.
    Replaced the main board twice now will try the Tcon.
    Did you get it fixed??
    Racso
    • selldoor
      Slow Learner
      • 7870
      It is not much use if you dont quote the exact numbers of both boards - the one you had and the one you got - Pictures of the labels would be good.
      Problem may be that this board 431C4A51L01 is very similar to 431C4Q51L01
      but one is for a Chimei panel and one is for a samsung panel so second question would be what panel have you got?
        Check LVDS cable fully seated.
        • Ryan.man
          by Ryan.man
          02-04-2025, 12:23 PM
          09-06-2024, 05:27 AM
        • sigmeyer
          Toshiba 50UL4B63DG faulty screen?
          by sigmeyer
          I got this 50 inch tv the screen starts off with almost nothing visible but the top part of it , and it would slowly kick in and the picture would be visible , but then over time it would go greyish with the top of it mostly intact. I did have instance where the screen would be fucked like that and i would touch the cpu and memory to see if it would react and a couple times it would screech on the speakers and restart. After that it would show a better picture somewhat but afterwards i touch the cpu and not much is achieved. Im wondering is this a screen fault or should i pursue this with a donor...
          08-30-2025, 08:13 AM
        • reformatt
          by reformatt
          07-31-2025, 08:37 PM
        • ahoonid
          MacBook Pro A1398 L2013 weird jumping screen.
          by ahoonid
          Hey everyone.
          I have a 820-3787-06 board from a MBP A1398 which has a screen issue. The problem starts with a bit of noise just like old TVs when booting and when the OS is on, screen jumps are added to the little noise on the screen. The jumps are millisecond and go back to the original place.
          Since there's a little crack in the corner of the screen, I thought it has to be the display. But to my surprise it wasn't since I tried it with a fully functioning screen.
          The same issue isn't happening with an external display. I did a gpu/cpu stress test on external...
          02-07-2024, 05:56 AM
