Sony XR-55X90J 5 blinks
  • matwan
    • Sep 2012
    • 7
    • Poland
    I have problem with SONY 55X90J. After several check status is as below;
    1. Running power board as stand alone:
    TCON_12V =~ 12.6V
    EVDD V On Max 24V= 19V.
    2.
    Running power board with TCON as stand alone:
    Effect as below, attched.
    3. When bottom LVDS cable is disconnected no blinks, but of course no TCON 12V and EVDD.
    "I'm almost sure it's a defective panel, but maybe someone has encountered a similar issue on their screen.
    Best regards.
  • Diah
    • Feb 2013
    • 6550
    if you disconnect only EVDD from T-CON side... did the error blinking gone?
    if yes... keep it disconnected and do hard reset for the TV... give time for it until it stay on and can hearing the first install melody
    • matwan
      • Sep 2012
      • 7
      • Poland
      Hello, no, with disconnect only EVDD from T-CON side error still blinking 5 times.
      And sorry, correct model is: XR-55A90J but can't update title of the post.
      • Diah
        • Feb 2013
        • 6550
        if the rand screen don't have damage.. invest with replacing T-CPN driver boards
        • matwan
          • Sep 2012
          • 7
          • Poland
          I have used 2nd TCON but from 65 inch model, first EMMC memory has been copied from original TCON but result is the same .
          • lotas
            • Jan 2016
            • 4841
            • Russia
            Sony often has a problem with the LVDS cables themselves (V-By-One FFC), try to find them and check.
            • lotas
              • Jan 2016
              • 4841
              • Russia
              Also, if you have an LG T-CON panel, there's a special adapter for testing the OLED panel (standalone mode, with color cycling) available on Aliexpress.
              • matwan
                • Sep 2012
                • 7
                • Poland
                Hi Lotas, thank you. LVDS cables checked, looks OK.
                • jason123
                  Sony XR-55A80J OLED TV 5 blinks - Troubleshooting steps
                  by jason123
                  Hi there,
                  I see a couple of posts related to the troubleshooting of similar TV. The one I have is acting slightly differently and I'd love your help.
                  So it has the 5 blinks. Previous owner got a TCON, no luck. Got a new Main board (though he didn't do the USB firmware update), again, no improvements.
                  I see 2 posts that are relevant:
                  https://www.badcaps.net/forum/troubl...j-oled-5-blink
                  https://www.badcaps.net/forum/troubl...g-hardware-dev...
                  10-29-2025, 02:01 PM
                • iglitare
                  by iglitare
                  09-04-2025, 07:13 AM
                • kca
                  by kca
                  Hello all ~
                  08-31-2025, 06:38 AM
                • thelankanguy
                  Sony KD-55X9000F TCON Issue
                  by thelankanguy
                  The TV shows a black screen with no image.
                  TCON ribbon connectors were disconnected individually for image and there was no half image even.
                  Later both ribbons were disconnected and TCON voltages were tested.
                  12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
                  There is also a short to ground in this circled inductor.
                  Is this a TCON issue or something else ?...
                  12-13-2024, 12:27 AM
                • GoodCapDude
                  Sony XBR-75X940E intermittent 6 blinks error code
                  by GoodCapDude
                  Hi everyone. First post on Badcaps!
                  I am trying to fix a Sony 940E from 2017 that either starts normally (and works perfectly until turned off) or goes straight to the 6 blinks error code without showing anything on the screen. It is frustrating to know that it can still work perfectly but is barely usable because of the difficulty starting it up. I am willing to try to short the BL_ERR but I would like to avoid that if possible. Does anyone have a view on this? Thanks a lot....
                  09-20-2025, 06:07 AM
