TV Samsung UE55HU8500L (2014) – service menu + firmware reflashing advice needed
This topic has been answered.
  • Robby-Gr
    • Sep 2025
    • 22
    • Greece
    Originally posted by Davi.p
    i tapped the link someone gave to you, i do not find the instruction there, since you seem not practical, i suggest you to ask what to do of what you see exactly before doing actions..
    Hello Davi.p,
    The link Diah gave me had 39 very useful photos that clearly show the settings I need to make. When I tried to open the link yesterday, nothing showed up, but today—after hearing from you and Diah—I disabled my firewall and was able to see all those photos!
    I also found this link on Samygo.tv from mbjr (https://forum.samygo.tv/viewtopic.php?p=66096#p66096) which contains a text file with a large number of settings, probably from an EEPROM dump.
    So, I have a lot of work ahead of me, but the key is getting into the extended service menu, just as you and Davi.p advised.
    Thank you all very much. I'll update you in a few days after I get everything I need.
    • Robby-Gr
      • Sep 2025
      • 22
      • Greece
      Originally posted by Diah
      the link i gave you are threat name Defult Service Menu Setting UE65HU8500 , at first post there are link for the photos of service menu.
      Yew Diah the link you gave me had 39 very useful photos that clearly show the settings I need to make. When I tried to open the link yesterday, nothing showed up, but today—after hearing from you and Diah—I disabled my firewall and was able to see all those photos!
      I also found this link on Samygo.tv from mbjr (https://forum.samygo.tv/viewtopic.php?p=66096#p66096) which contains a text file with a large number of settings, probably from an EEPROM dump. Thanks so much I have lot to do and inform when I am ready.
        • 12264
        • U.S.
        You have post #7 as selected answer, are you sure that's the one you choose?
        • Robby-Gr
          • Sep 2025
          • 22
          • Greece
          Dear friend nomoresonys, although I'm new to the forum with few posts, and I might have made a mistake, I checked, and I believe I have the correct answer and recipient. If you have any suggestions for me, I'd be happy to hear them. Kostas
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4450
            • Italy - Milan
            Don't bother other users with useless questions. envious! Let them concentrate on the problem..
              09-07-2024, 05:50 AM
            • GeckoGreen
              Samsung service bulletin: need firmware file for PN63C550 TV
              by GeckoGreen
              I'm hoping someone with access to the Samsung GSPN can help me. I need someone with access to download a firmware file for my PN63C550 TV, as it will fix a problem per the Samsung service bulletin.
              You can reference Samsung bulletin #:ASC20130528001 and I need the [2D63]LOGIC.bin file please.
              The full service bulletin is linked here: https://www.avsforum.com/attachments...3-pdf.1080602/
              Will you please help me get the [2D63]LOGIC.bin file for my TV?
              05-17-2025, 02:47 PM
            • sikocan
              NP930XED Samsung Galaxy Book2 Pro Laptop PD Firmware Loop
              by sikocan
              I hope this message finds you well. I wanted to share a recent experience I had with a laptop that had a Type-C Port issue, specifically related to a PD (Power Delivery) controller problem. After replacing the damaged PD controller chip with a new one I purchased from AliExpress, the laptop now charges properly and negotiates power as expected, allowing the device to power up. I've replaced this chip twice just in case.
              However, it seems that the laptop's BIOS is detecting an older version of the PD Firmware on the newly installed chip. As a result, it attempts...
              01-11-2024, 01:47 AM
              LCD LED TV Service Menu Codes
              ALL LCD LED TV SERVICE MENU CODES
              Service Menu Code with Board Name
              China Universal Board / Jumper Board Service Menu Code
              Changhong Ruba Service Menu Code
              Ecostar LED TV Service Menu Code
              Orient LED TV Service Menu Code
              Haier LED TV Service Menu Code
              TCL LED TV Service Menu Code
              Samsung LED TV Service Menu Code
              LG LED TV Service Menu Code
              Videocon LED TV Service Menu Code
              Supra LED TV Service Menu Code
              Toshiba LED TV Service Menu Code
              Symphony LED TV Service Menu Code
              Veste/ LED TV Service Menu Code...
              10-31-2024, 03:58 AM
            • Mirenia
              Samsung UEMU6199U - no Standby - bad Firmware?
              by Mirenia
              I've got a Samsung UEMU6199U which has no Standby LED and no reaction if try turning it on.
              Voltages on the power supply board is okay. Backlight test is also okay.
              I read about a corrupt firmware on IC1604 on some models, did a dump of this IC and turns out: First sectors are empty.
              So I think my TV has exactly this issue.
              Can someone please fix the dump?
              And how do you do that?
              As I understand you fill in the empty sectors and leave the rest as it is. But where do you get the "information" of what you...
              05-12-2025, 06:13 AM
