I am getting frustrated with this tv. When I turn on the tv, it eventually starts clicking and I can test all the voltage output after the click, then the voltage goes to 0v. I can't take any voltages without it jumping around. I tested the ESR on all the electrolytic caps and they were good. When testing the voltages on the LDO in the 5v stby circuit, the input jumps around between 5-5.2V. Since I can't get a steady 5v stby I can't even shunt the RL_On to 5stby so I can test the voltage outputs without them jumping all over the place. Can I use an external 5V source to get the 5V on the standby, any suggestions?
LG60PC1D no power-frustrated
This specification for the Acer Aspire A717-71G-552V Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A717-71G-552V boardview and A717-71G-552V schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 05:54 AM
by marce002Hello
Need just to know how do you guys determine what the problem is, when we have some fluctuating volt, to discard a faulty TPS 51125 , or if the issue is after this IC.
CRAZY JUMPING
PP3V3_S5 = 0v to 3.33 v jumping
PPBUS_G3H = 12.4v to 12.48 jumping a little
PP5V_S5 = 2v to 5v aprox, jumping fast
P3V3S5_ENTRIP = crazy jumping from low volt
SMC_PM_G2_EN = jumping 0v to 3.3v crazy
STEADY
P3V42_G3H=3.39V steady
PP5V1_CHGR_VDD=5.06v steady
PPCHGR_DCIN= 18.29 to 18.31 jumping
by CapLeakerSo I bought this LG 65UQ70 today at Walliworld. Put the wall mount on, set it up, worked for 30 mins and then I get these jumping horizontal bars. Let the TV do updates and let it cool down for 5 mins. Worked perfect for 2 mins. As soon the TV is warm I get the jumping vertical bars again.
Keep the other TCL thread in mind. Now I am questioning are all COVID 2022 / 23 TV’s bad or what? That’s two 65” TV’s one from Amazon and this one from Walmart. What are the chances on that?
I guess this one goes back either later today or tomorrow morning, unless... -
by JohnML1975Hello All
Started working on this TV today
As I remove the back will share some photos and findings
The problem I am having is in the title of this thread
I still need to proceed my trouble shooting
Started a thread so that I can share with all
Any inputs are welcome -
by roddDear all,
I am trying to repair the ATX power supply.
First I fixed the +5V stby, which was zero due to a shorted TNY279 and an open 2R2 resistor.
Just in case I replaced the PWM control IC (PS223) and the PFC control IC (CM6800).
Now the supply turns on, the +3.3V is fine, but the +5V measures only 2.5V and there is no +12V.
I have checked every diode I could find with a DMM (in circuit) and all the capacitors (in circuit) no shorts, low ESR.
In despair I removed the low voltage diodes which were all mounted on the same heatsink... - Loading...
