Lg 47lw5400
    Re: Lg 47lw5400
    Also when testing the power board again I get normal voltages except for the power-on 24v in this pic: https://picasaweb.google.com/lh/phot...eat=directlink
    I only get 3v what is this and is this my issue?
      Re: Lg 47lw5400
      you mean 3v on the PWR-ON pin or on the 24V pin ?
      i"m attaching the schematics to this model , maybe it will help you
        Re: Lg 47lw5400
        3v on the pwr-on pin.
        Thanks!
          Re: Lg 47lw5400
          you welcome
          i have a similar problem with my LG LED and the voltage on the PWR-ON is 3v as well
          not sure if it helps :-/
            Re: Lg 47lw5400
            Originally posted by bil99 View Post
            you welcome
            Does yours work properly?
              Re: Lg 47lw5400
              it doesn't work properly but in my case i believe the problem isn't the power board , it's probably the tcon or the panel itself.
              but nobody helps me so i"m not sure exactly what it is
                Re: Lg 47lw5400
                What are your symptoms?
                  Re: Lg 47lw5400
                  mine is a bit different and also it had a slight water damage as a few drops of water fell on the top and slid all the way down causing some oxidation on the left panel board at the bottom and ever since i have only backlight and no picture
                  you check it out here but no one seems to help me :-\
                    Re: Lg 47lw5400
                    sounds kinda like mainboard or panel to me, but again I am not too good at diagnosing. I have sort of the same symptoms. I had a black screen, but did get the blue power light. I replaced the mainboard and got some display, but I think the mainboard I got was defective and shipped it back. Now I think I am going to give up and try and get what I can out of it.
