I need help to unlock bios for my HikVision DVR with unrecognised password after firmware update. Please help me to get acces back. Bios is for ds-7208huhi-k1
HikVision DVR bios unlock ds-7208huhi-k1
I did write a backup from same type DVR but with a known pass and I have acces on my local network, but I can't use it with cloud HikConnect because has a serial and mac address from donor board that is in use. Do you think that the identified string will work as a password if i will flash back my original backup file (it's a pain in the "a..." to do it, i have to unsolder and solder back the chip that's a QFN one)Comment
Your firmware with the device feature file has been implemented and tested successfully.
Upgrade Instructions:- Format a USB flash drive.
- Copy digicap.dav to the drive.
- Use the "Upgrade" button in the Hikvision user interface to update.
Important:
Ensure your SPI chip has been flashed with the exact motherboard ID dump before performing the UI upgrade. If not, flash the BIOS/SPI chip with the correct firmware dump first, then proceed with the attached file.
Good luck!
Attached Filesif you find these attachements useful please consider making a small donation to the site
Thank you for your kindness. If I understand correctly, this will reset the password from my locked backup bios and then I will have acces to my DVR? I ask this because if i flash the original locked bios back I will not have acces to upgrade via USB.
Important:
Good luck!
Later edit:
I have compared yours with updated firmware for my device and is exactly the same as: DVR-K71_EUROPE-ML_STD_V4.20.001_Build_190430. I updated my working DVR with this one (Now it had a different serial number because it comes from a donor firmware), I would like to use my original SN (which had a lost password) not the donor one. ThanksComment
The FIle I provided will patch your SN. So You Dont need SN Modifications. Just flash a unlocked clean dump and then process this USB upgrade file . you will be done. Have a good Day, Keep In Mind that changing or modifying SN is Prohibited in some countries. So Take Your Own Risk & Execute. Have A GOOD DAY.
Later edit:
Channel: BIOS Requests ONLY!
by macabookHello everyone,
07-24-2025, 02:17 PM -
by cr4zychrissHello everyone,
I have successfully used a CH341A programmer and can read/write/verify both flash chips, but using my backups/extractions has failed to restore power. The root cause is likely a corrupted Intel Management Engine (ME) region or an incompatible EC/BIOS pairing. System & Hardware Details- Barebone / Chassis: TongFang GK7MRFR
- MB: MB: GK5MP5X V1.0 Prod :GK5MRFV10T04201310281
- Rebrand: PC Specialist
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
by piratiHello everyone,
- Loading...
