is the dlp chips located on tcon?
  • mattstolte
    • Dec 2013
    • 612
    • usa
    I've never fixed a mitsubishi dlp but I tooken apart some for parts and the chips are located on the tcons right?@
    Re: is the dlp chips located on tcon?
    DLP TVs don't really have a T-con. There's a board called the DMD carrier/controller (Digital Micro-Mirror Device) which carries the DMD (the "DLP chip") and associated hardware for controlling it.
    The DLP/DMD will be connected in some way to the light engine / optical path.
    Disclaimer, I have never fixed/worked on a DLP set.
    • kca
      by kca
      Hello all ~
      08-31-2025, 06:38 AM
    • ugamazing
      Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
      by ugamazing
      I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
      08-31-2022, 07:34 AM
    • x_orange90_x
      TCL 50S535 bad tcon or panel issue?
      by x_orange90_x
      Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
      03-29-2025, 11:02 PM
    • Hakuu
      by Hakuu
      Hi There,
      More Details
      TV Model - LG OLED77G1PUA
      07-12-2023, 02:37 PM
    • netgearnetgear
      TCL 43S423 TCON OR PANEL FAULTY???
      by netgearnetgear
      Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
      08-20-2025, 06:04 PM
