Sony KDL-32EX310 does not turn on in the morning
  • Behemot
    • 4845
    • CZ
    I got this TV which supposedly had troubles turning on in the morning, the problem was getting worse to the state that the owner had to unpug the AC and plug again for the TV to power up. Lately it was not turning on at all and twice deleted all programs.
    I first thought it was capacitor problem but all except three small caps are japanese either Chemi-Con, Rubycon or NCC. All of them measured fine. It turns on and of smoothly ATM. I will let the TV sit to the morning and see if it fires up or what.
  • splitcrete
    • Dec 2012
    • 387
    • usa
    Re: Sony KDL-32EX310 does not turn on in the morning
    Did you check your on/off timer ? If not that do a factory reset.
    • Behemot
      • 4845
      • CZ
      Timer is off.
      • splitcrete
        • Dec 2012
        • 387
        • usa
        Post clear pictures of the boards front and back,and voltage readings.
        • Behemot
          • 4845
          • CZ
          New information - I've been told about an indication of the upocming problem in the morning: while still running in the evening, the program menu does appear anymore when opened.
          All voltages are within normal parameters, that is +3,3 V stand-by, several +12 V and +24 V rails. The higher ones are a bit high (12,6 and 25,6 V). Than there is some separate rail for T-con about 3 V and AC OFF detection at 2,9 V.
          And oh, the TV is only couple of months after warranty period.
          • kasfamily
            • Aug 2014
            • 774
            • Russia
            LED blinks the number of times
            • Abel Bejan
              Sony Vaio does not turn on, overheats
              by Abel Bejan
              I am quite noob in advanced electronics, however I'm trying to fix a Sony Vaio PCG-71211M laptop mainly because I love old hardware. I don't want to send it to a technician because this computer is not important for me, I want to fix it as a hobby.
              Shortly, this laptop does not display any video output when turned on, no POST, nothing. The keyboard leds are on and I can actually turn Num Locks on and off. Sometimes the laptop turns itself off straight away, sometimes, mostly after some attempts, the laptops enters a loop in which the cpu fan spins very aggressively and the CPU,...
              01-11-2025, 10:11 AM
            • odie34
              Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
              by odie34
              I am a hobbyist (not a professional) so please be gentle...
              I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
              I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,...
              02-18-2024, 09:11 AM
            • pajdek
              Lenovo Y700-17ISK turn on and off
              by pajdek
              Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
              09-20-2023, 02:49 AM
            • Highvoltagerchelie
              Sony XBR-65Z9D won't turn on after lighting strike
              by Highvoltagerchelie
              Good afternoon. I found this forum as I was looking for troubleshooting information for my Sony z9d. A lightning strike hit very close to the house and did nearly $30,000 in electronics damage. The TV appears completely dead with no status light and no picture. I found the Sony XBR-65Z9D service manual and followed the troubleshooting steps on Pages 21-26. All checks seem normal except DC_OFF_DET check on Page 23 R420 voltage was slightly higher than 3V. It was 3.475V and C418 was slightly higher that the 5V at 5.3V.
              I proceeded to check the Power Board CN6401 connector. With all...
              View and Download Sony XBR-65Z9D service manual online. GN2TR CHASSIS. XBR-65Z9D lcd tv pdf manual download.
              11-30-2023, 04:49 PM
            • Dreamcazman
              Sony KV-XJ29M31 CRT TV - Very dim image on turn on
              by Dreamcazman
              Hi all, I recently picked up a Sony KV-XJ29M31 CRT TV (BG3R chassis, Australian model) cheaply & completed the RGB mux mod on it for some retro gaming. That worked great, however, I have another problem which I hope someone can help me with or at least steer me in the right direction.
              Basically, the issue is when it's cold, it takes a while (like 2 mins) for the picture to come up. I think the image is there, it's just very dark or dim. I can hear the degaussing sound & I can change inputs & hear audio but no image.
              Once it's running properly, it keeps...
              02-28-2022, 07:47 PM
