White screen and buzzing with Samsung PN50C7000
  • Recon286
    • Aug 2014
    • 5
    Hello all,
    So I have a Samsung PN50C7000 that has worked wonderfully for the last 4 or so years. Never had any of the other issues people have had (pink bands, green lines, excessive buzzing) and have been extremely happy with the picture. Recently though, it's manifested an issue with the screen and I have been unable to find any info on it. The issue is whenever I turn it on now, the screen is totally white, flickers a bit, and a terrible buzzing noise can be heard (loudest from the noise filter on the main AC power input). I suspect some component/board is failing but have no idea which. See the video here: https://www.dropbox.com/s/xr31jf9n4k..._115640015.mp4
    Interesting details to note:
    1) It started kinda off and on at first. I would turn the TV on, it would flicker/buzz and then a good picture would come on and stay on the whole time the tv was on. One time after it went white and started buzzing I just cycled through the inputs a couple times and it came back up. It's died and come back to life three or four times now.
    2) After one of the times it died, I bought a new power board off Ebay and replaced it. Worked fine after that for several weeks, then it started doing it again and ultimately stayed broken. I have looked at both boards and can't seem to find any swollen caps, blown fuses, or anything obvious.
    3) When it is broken, audio is still working fine (you can probably hear it in the background in the video, I think Supernatural is on).
    4) Also while broken, in addition to the faint buzzing that I think is somewhat normal (sounds loudest from the logic board area) the main power noise filter buzzes like crazy, you should be able to hear it in the video.
    5) It's hard to make out, but there is a faint image retained from the last time I played Diablo 3 at the very beginning of the video. Interesting thing though is this was NOT the last image displayed on the screen before it died this last time.
    6) No menus pop up when you hit them on the remote, but it appears to still be controlling the TV (channels change, inputs change, etc.)
    Anyone have any thoughts what component could be failing? I'd really like to keep this TV as I hate all LCD/LED pictures (this TV really spoiled me), and any new plasma with a decent review and more than 2 inputs is ~$1200. Not to mention it seems like probably an easy fix if I only knew what part to replace.
    Thanks all!
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: White screen and buzzing with Samsung PN50C7000
    Logic/control-board....?
    Have you tried the built-in test-patterns....
    TELEFIX
    • Recon286
      • Aug 2014
      • 5
      Thanks for the reply. I have not tried any test patterns. Is there a good reference to walk me through doing that?
      • Recon286
        • Aug 2014
        • 5
        So I tried accessing the service mode the way a few sources state (power, mute, 182, power) but that appears to do nothing. Speaking generally though, I can't see any menus at all when the TV is powered on. Even with no input when the TV is powered on you should be able to see a menu on the screen, but I can't. The menus are definitely there and switching though, as I can hear when I change inputs. So does this point to a main board issue? Logic board? Panel? Anything else?
        • harp
          White screen repairs
          by harp
          To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
          Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
          On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
          05-13-2024, 03:43 AM
        • Chrissygizmo
          samsung galaxy ao2s very temperamental after screen replaced
          by Chrissygizmo
          Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
          Ive eventually managed to get it on and working but it's very temperamental...
          The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
          05-26-2024, 12:05 AM
        • Kiberge
          Samsung LH82QENELGC/EN Help needed - Static line on screen
          by Kiberge
          HI guys!
          I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
          I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
          the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
          This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
          04-22-2024, 11:28 AM
        • Ryan.man
          by Ryan.man
          02-04-2025, 12:23 PM
        • aczelkri
          Samsung LE37B650 white screen
          by aczelkri
          Hey guys,
          I have a Samsung LE37B650 screen with the following symptoms:
          - Image suddenly turned into almost completely white while I was watching a movie. I can make out some details, but they are very faint. There is definitely an image there, but very very bright and maybe inverted colors.
          - If I unplug the cable between the main panel (that has all the video in-out ports) and the tcon board (T315HW02 V3 CTRL BD 31T06 C03), the screen is black as normal (there is backlight and it is masked by the pixels), but of course there is no actual...
          10-14-2020, 05:10 PM
