Plasma TV - Flashing white screen and buzzing
  • Recon286
    • Aug 2014
    • 5
    Hello all-
    So I have a Samsung PN50C7000 that has worked wonderfully for the last 4 or so years. Never had any of the other issues people have had (pink bands, green lines, excessive buzzing) and have been extremely happy with the picture. Recently though, it's manifested an issue with the screen and I have been unable to find any info on it. I suspect some component/board is failing but have no idea which. See the video here: https://www.dropbox.com/s/xr31jf9n4k..._115640015.mp4
    Interesting details to note:
    1) It started kinda off and on at first. I would turn the TV on, it would flicker/buzz and then a good picture would come on and stay on the whole time the tv was on. One time after it went white and started buzzing I just cycled through the inputs a couple times and it came back up. It's died and come back to life three or four times now.
    2) After one of the times it died, I bought a new power board off Ebay and replaced it. Worked fine after that for several weeks, then it started doing it again and ultimately stayed broken. I have looked at both boards and can't seem to find any swollen caps, blown fuses, or anything obvious.
    3) When it is broken, audio is still working fine (you can probably hear it in the background in the video, I think Supernatural is on).
    4) Also while broken, in addition to the faint buzzing that I think is somewhat normal (sounds loudest from the logic board area) the main power noise filter buzzes like crazy, you should be able to hear it in the video.
    5) It's hard to make out, but there is a faint image retained from the last time I played Diablo 3 at the very beginning of the video. Interesting thing though is this was NOT the last image displayed on the screen before it died this last time.
    6) No menus pop up when you hit them on the remote, but it appears to still be controlling the TV (channels change, inputs change, etc.)
    Anyone have any thoughts what component could be failing? I'd really like to keep this TV as I hate all LCD/LED pictures (this TV really spoiled me), and any new plasma with a decent review and more than 2 inputs is ~$1200. Not to mention it seems like probably an easy fix if I only knew what part to replace.
    Thanks all!
  • harp
    White screen repairs
    by harp
    To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
    Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
    On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
    05-13-2024, 03:43 AM
  • Ryan.man
    by Ryan.man
    02-04-2025, 12:23 PM
  • kca
    by kca
    Hello all ~
    08-31-2025, 06:38 AM
  • EazyBone
    Sharp LC-65Q620U White Screen
    by EazyBone
    Another TV topic!!
    I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
    The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
    Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
    08-21-2024, 12:56 PM
  • hcinne
    Dell G15 ryzen edition black screen 2 amber 1 white
    by hcinne
    I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the...
    07-23-2024, 07:56 AM
