Good evening, my DVR is locked. I need a dump to unlock it. Can you help me? Thanks.
Hikvision ds 7104 Hqhi main ds-80303
by goodoaneI need help to unlock bios for my HikVision DVR with unrecognised password after firmware update. Please help me to get acces back. Bios is for ds-7208huhi-k1 ...
by jovani1989HikVision DS-7104HQHI-K1 Motherboard: DS-80303_P REV 2.0 and SN: C47579229 Firmware dump or unlock required. Thank you!...06-11-2025, 01:54 PM
by cheeky2I suppose the real question is whether the existing pinouts from ether a 17IPS71 psu are cross compatible with a 17IPS12 psu? If they are then the exchange of the main boards should have no issues providing the screen is compatible with both main boards. Obviously you can change the screen configurations easily enough (providing you have the correct files) for the main board. Why may you ask would I do this? Well a lot of the smart features are no longer working on a Hitachi 48HBT62U main board I wish to give it a new lease of life!
Obviously the same LVDS connector for the screen connection... -
by Dani_2024Hi and thanks in advance for any input you might provide!
Last Sunday I was watching a dvd and fell asleep for about half hour, when I awoke the tv screen was black and couldn't get the dvd menu to show, so I changed the input to antenna and had sound but no picture, turned it off. I then got online and found this great site! ....read many troubleshooting tips and this...5 Photos -
by Modify_incI have a Inspiron 11 3185, and in the BIOS setup under Security it shows "Locked Setup", which limits pretty much everything in the BIOS. I'm using bios-pw.org to generate the codes for the hash, but they never work for the Locked Setup password. The codes generated for the System password and the HDD password work fine, but the code for the Locked Setup password always fails. I don't understand, if it works for the first two, why is it not working for the Locked Setup p/w? Since I can't disable it, anytime I reboot, even after a Windows update, I have to go through the hassle of generating...
Channel: BIOS Requests ONLY!
- Loading...
