Sony KDL-37S550 - bad image - not gamma chip but same effect
  • flocko
    • Nov 2012
    • 1121
    • uk
    Re: Sony KDL-37S550 - bad image - not gamma chip but same effect
    Hi I use chip quik (ebay item number 221524424094)to remove old chip and a good regulated temp solder station with a small pointed tip ,that way you don't over heat the board with hot air you can remove surrounding items without wanting to,use lot of no clean flux taking off and replacing the chip,clean off the old solder with flux and wick and Q tip, make sure to line up chip and board marker , line up chip pins then tack on one corner, check all pin are in line then tack opposite corner check pins are all still in line more flux and solder the rest of the pins,I also have a digital microscope so I can check my work that helps as I can run it over the board to make sure all is looking good . There is a lot of good smd soldering stuff on youtube Flocko
    • noledud
      • Dec 2013
      • 413
      • united kingdom
      update on this i followed advice and i did my next gamma chip myself
      im pleased to say it was a success and not that difficult, i did it exactly the same as flocko above
      glad i did it as i have had someone do my gamma chip replacments at a cost so saving all the time now
      brilliant thank you all again
      • flocko
        • Nov 2012
        • 1121
        • uk
        Thanks for the follow up noledud,pleased that it worked for you as well, I buy my AS15-F chips from China at about £8.00 for ten and have not had a bad one yet. And I am now trying a new low cost low melt solder to remove them that is on eBay UK at £7.00 for 1M so far so good and keeping the costs down Flocko
        • acedogblast
          by acedogblast
          11-02-2024, 05:13 PM
          Common SPI bios chip programming Questions and Answers
          by SMDFlea
          Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
          A: If you can`t read from it how do you expect to write to it ?.
          Q: Why is my bios chip unreadable ?.
          A: The programmer is faulty or has a worn or broken zif socket.
          The USB cable is frayed,connector pins worn or some other physical damage.
          Not enough amperage or voltage to power the programmer properly.
          Bad...
          09-02-2021, 04:40 PM
        • DynaxSC
          ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
          by DynaxSC
          Hi
          I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
          08-04-2025, 12:20 PM
        • mich6el
          Imac 2020 a2115 no image after reblays T2 Security chip
          by mich6el
          Hello! Has anyone encountered problems on the Imac 2020 27 inches with a T2 chip? I had to replace 2 T2 chips on two iMacs, the first one was successfully replaced, tested and given to the client. The second iMac after replacing the T2 is flashed, the system is installed through the target mod, it boots into the system, you can hear me tapping on the keyboard, but the image does not display (and to an external monitor​). I reballed the T2 chip, changed the processor, RAM, display. No positive result! My friend said that he had 2 such devices and on both of them, after replacing the T2 boards,...
          04-22-2025, 02:05 PM
        • BMCappelletti
          Asus Chromebox CN62 - wrong chip put on BIOS reader
          by BMCappelletti
          Long story short:
          - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
          - gave the computer to his son a couple years later
          - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
          - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
          (seems like the story was not that short)
          He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
          01-08-2025, 07:27 PM
