PHILIPS 75PUS7805/12 BLACK SCREEN
  • Diah
    • Feb 2013
    • 6613
    before you put all together,, test the LED which didnt come on. if there zener diode build inside the LED are open or short... with yours DM in diode mode you will se one one way lit dim and at reverse will read diode.. in case there are zener protection built in
    • bohaboha
      • Nov 2012
      • 1047
      • sweden
      #62
      the 2 LEDs that did not come on both read 2.500v and dim and both OL in Reverse. so it looks that there is no zener build inside them. did you read post60? and what do you think about the behave of the TV set
      • lotas
        • Jan 2016
        • 4905
        • Russia
        #63
        Why are you supplying power (voltage) inside the power supply (to the output of the LED drivers)? You can burn out the LED driver itself this way. If you haven't already, you should always disconnect the connector from the power supply and supply power from the tester to the backlight wires!
        • Diah
          • Feb 2013
          • 6613
          regards to yours POST #60 you still have the old strips. use good one to replace the strips with LED off, and power on the TV let see if there any change.... other wise you have fault strips delivered
          • bohaboha
            • Nov 2012
            • 1047
            • sweden
            #65
            ouch hope nothing happened yet thank you for the information
            • bohaboha
              • Nov 2012
              • 1047
              • sweden
              #66
              i did already contact the seller about the LEDS will see what he answer but old and new 'LEDS mixed it is not a very good idea but for testing ok
              • Diah
                • Feb 2013
                • 6613
                LOL. i am not telling you to use them... we need just to test to see if any change about the OFF LED and the dim one, also no need to install on chassis , just plug them at the plug of the defect one
                • bohaboha
                  • Nov 2012
                  • 1047
                  • sweden
                  #68
                  I did try with three row from my old LEDS ( i tested as lotas prevent me to do)from the set it acts the same but my LEDS Shine better in Dim situation and this situation make me very uncomfortable any how i get an answer from the seller jere what he say :
                  New message from: hhhelectronic (2,545)
                  Hello ,
                  I consulted my engineer again,they told me if the led strips can normally light in tester,they are ok.
                  Could you please test them each strip by each strip again?If they normally light, no problem with the led strips.
                  Then it is possible there is a problem with the power supply(motherboard or constant current board)
                  Please don't worry,if the item not light in tester,i will send you a replacement.
                  Look forward to your reply.
                  ​but with LED Tester they work
                  • Diah
                    • Feb 2013
                    • 6613
                    you need to believe on PSU circuit not the tester as it keep push current even there are fault. point.
                    • bohaboha
                      • Nov 2012
                      • 1047
                      • sweden
                      #70
                      i did it with PSU the test you asked me to do
                      • bohaboha
                        • Nov 2012
                        • 1047
                        • sweden
                        #71
                        [QUOTE=Diah;n3771245]you need to believe on PSU circuit not the tester as it keep push current even there are fault. point.[/QUOT
                        Hello now I'm waiting for the seller's answer and in the meantime I'm going to look at the backlight drive or maybe better not to touch it because the new LEDS are not ok
                          • 12323
                          • U.S.
                          #72
                          Must be defective leds, just have the seller send new ones, if he has none get a refund and buy from someone else.
                          • bohaboha
                            • Nov 2012
                            • 1047
                            • sweden
                            #73
                            Hi nomoresonys yes i did contact him am waiting his definitive answer . better to wait for the backlight
                            • bohaboha
                              • Nov 2012
                              • 1047
                              • sweden
                              #74
                              Hi all just to inform you with this good news the seller send me a new set of backlight hope this time it will be ok it is on the way
                              • Diah
                                • Feb 2013
                                • 6613
                                good, let us know, hope you dont need to put the PSU under Operation Knife LOL
                                • HTR-Informatique
                                  by HTR-Informatique
                                  02-09-2025, 06:51 AM
                                • VcemPzd
                                  Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
                                  by VcemPzd
                                  Hello everyone !
                                  My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
                                  04-28-2025, 10:14 AM
                                • kca
                                  by kca
                                  Hello all ~
                                  08-31-2025, 06:38 AM
                                • DaniK
                                  Acer Aspire E5-574-52RH - black screen
                                  by DaniK
                                  I have this strange behaviour with Acer Aspire E5-574-52RH, i5 6200U, intel graphics, DA0ZRWMB6G0 Rev G, model ZRW.
                                  Laptop came in for a SSD upgrade, took everything apart to install the SSD.
                                  Everything started after modifying BIOS settings to boot UEFI instead of Legacy.
                                  Laptop works fine, i installed windows 10 and drivers/updates, everything works ok(when it works)
                                  The black screen problem is random, maybe 5 out 10 times, laptop remains with the black screen, no image
                                  Symptoms are:
                                  - random black screen after displaying Acer logo...
                                  02-21-2024, 06:27 AM
                                • turmix
                                  AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
                                  by turmix
                                  Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
                                  The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
                                  At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
                                  During another reassembly, I made a mistake, and...
                                  01-29-2024, 03:48 AM
