PHILIPS 75PUS7805/12 BLACK SCREEN
  • bohaboha
    • Nov 2012
    • 1027
    • sweden
    Originally posted by bohaboha
    Hi lotas and thank you so my test procedure was wrong then how should i test it black probe to C8622NC and the red probe to VLED+ if I have understood correctly?
    Hello everyone after a difficult time of illness now I am ready and count on your support. Now I have got the new backlight for this huge TV that is on the bed as you can see.
    Is it normal that it should read 42.3V with all the lights on this is when I test with backlight tests regardless of whether it is two rows that are tested or the whole set.
    but when i connect everything together without putting the tv together and turn on all the lights are on but very low light and of course i don't expect that you would see any picture of the low light intensity.
    I get very doubtful is there anyone who can give an explanation
    Thanks in advance
    • bohaboha
      • Nov 2012
      • 1027
      • sweden
      Originally posted by lotas
      The backlight is never connected to the common ground! Power + is constantly supplied to the backlight connector, and - (negative) is disconnected, adjustable, controlled by the backlight drivers via mosfets. Here is your connection diagram...
      Thanks in advance
      • lotas
        • Jan 2016
        • 4865
        • Russia
        Your backlight is connected in series - parallel (several channels are connected in parallel), connect and connect everything without a panel and supply power and see how the diodes will light up from the standard power supply.
        • Diah
          • Feb 2013
          • 6573
          at his first Post. he stated only ambient on, no Picture no sound... so what had this to do with LED BL ?
          his set had FRC function on main boards... this much likely Philips known fault chassis TPM206Eas Glitch at firmware .. need upgrade_loader.plg firmware to flash via USB formatted FAT32 in MBR Mode.
          • bohaboha
            • Nov 2012
            • 1027
            • sweden
            Hi lotas and thank you . Here what i get Screen and Tcon not connected but mainboard and of course power supply are connected the light is very dim sorry i have a problem to upload pictures just now i do it as soon i solve it but i hope you understand
            • bohaboha
              • Nov 2012
              • 1027
              • sweden
              #26
              Hi Diah it is true what you say but afterwards I discovered that there was a picture but no sound and I got sick and forgot to update you guys Sorry.
              but thanks for the information and reference it will surely be of use in the future
              • Diah
                • Feb 2013
                • 6573
                T-CON must be connected to MB then the LED BL will turn full current, no need to LCD.
                • bohaboha
                  • Nov 2012
                  • 1027
                  • sweden
                  #28
                  even with Tcon connected the LED BL same result is it possible it is not the right LED? I bought from : hhhelectronic
                  on ebay and he say that they are ok for this model
                  LED-Streifen Für 75PUS7354 75PUS7805 75PUS7855/12 CEJJ-LB750Z-8S1P-M3030-J-1 K-1 #388116982118
                  Inkorgen
                  • bohaboha
                    • Nov 2012
                    • 1027
                    • sweden
                    #29
                    Here are the pics
                    • Diah
                      • Feb 2013
                      • 6573
                      messure the LED BL Socket on PSU, the red cable with reference TV chassis , turn on and tell the high and low Voltage you have
                      • bohaboha
                        • Nov 2012
                        • 1027
                        • sweden
                        #31
                        Hi as you did not mention any tester i used my multimeter for this test here there are the yellow probe on chassis is the red one
                        • Diah
                          • Feb 2013
                          • 6573
                          you did this measurements only on RED cable right ? its strange reading ... can you tell yours original Strips, how many pieces and how many LED on each strip.. if you can show the wiring of the strip where they are fitting on chassis
                          • Diah
                            • Feb 2013
                            • 6573
                            write also the original Strips the printed label , the replacement we can see they are 3030 LED, there are 2 type double LED and single one..
                            • bohaboha
                              • Nov 2012
                              • 1027
                              • sweden
                              #34
                              there is 16 on each hole row all together 128 LEDS
                              for the measurement i did it for red and black and the result for the Red is the higher value
                              here is the backlight Data
                              • Diah
                                • Feb 2013
                                • 6573
                                original also 3030, use yours LED tester to light on just one LED from Original and replacement then compare the light strong and V and current
                                • lotas
                                  • Jan 2016
                                  • 4865
                                  • Russia
                                  #36
                                  You have all 8 LED strips connected in parallel, that is, they have one plus and one minus. If there are 16 LEDs in a strip, then 16 x 3v = 48v (the same as what your power supply supplies to the LEDs), and the brightness depends on the current strength.
                                  • bohaboha
                                    • Nov 2012
                                    • 1027
                                    • sweden
                                    #37
                                    [QUOTE=Diah;n3769325]original also 3030, use yours LED tester to light on just one LED from Original and replacement then compare the light strong and V and current[ Hi, both have 3V and the new ones look a bit stronger but I'm not sure because I'm testing one by one, I need to find a way to get them to light up at the same time with 2 half rows to determine, but how I can measure current with my Fluke 114 it has 2 holes.
                                    I've been thinking that maybe the new backlight LEDs don't fit but the seller answered very firmly that they would fit and that he sold several for similar TV models
                                    • bohaboha
                                      • Nov 2012
                                      • 1027
                                      • sweden
                                      #38
                                      Yes you a right. that's why they all lights up where ever i put my backlight testers probe on plus and minus . but the problem here the brightness is very low and do not get stronger when i power up the set whiteout the Screen as mentioned in my post i will try to compare 2 half row old and new stand alone to find out
                                      • HTR-Informatique
                                        by HTR-Informatique
                                        02-09-2025, 06:51 AM
                                      • VcemPzd
                                        Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
                                        by VcemPzd
                                        Hello everyone !
                                        My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
                                        04-28-2025, 10:14 AM
                                      • kca
                                        by kca
                                        Hello all ~
                                        08-31-2025, 06:38 AM
                                      • DaniK
                                        Acer Aspire E5-574-52RH - black screen
                                        by DaniK
                                        I have this strange behaviour with Acer Aspire E5-574-52RH, i5 6200U, intel graphics, DA0ZRWMB6G0 Rev G, model ZRW.
                                        Laptop came in for a SSD upgrade, took everything apart to install the SSD.
                                        Everything started after modifying BIOS settings to boot UEFI instead of Legacy.
                                        Laptop works fine, i installed windows 10 and drivers/updates, everything works ok(when it works)
                                        The black screen problem is random, maybe 5 out 10 times, laptop remains with the black screen, no image
                                        Symptoms are:
                                        - random black screen after displaying Acer logo...
                                        02-21-2024, 06:27 AM
                                      • turmix
                                        AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
                                        by turmix
                                        Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
                                        The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
                                        At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
                                        During another reassembly, I made a mistake, and...
                                        01-29-2024, 03:48 AM
