Toshiba 32AV502R - power cycling
  • dazz_rd
    • Aug 2014
    • 7
    I have a Toshiba 32AV502R which constantly power cycles. It will work for 5-10 minutes, turn itself off and back on. It will go back to normal for a few minutes and repeat the cycle, but the time it stays normal will decrease with every power cycle.
    I have checked all of the boards to see if there are any components that look damaged and everything looks good including all the capacitors. I have attached pictures of the power supply (that's where I think is the problem is). Any ideas on what might be the issue?
    Thanks in advance,
    Chris.
    Re: Toshiba 32AV502R - power cycling
    See this thread:
    https://www.badcaps.net/forum/showth...02R#post471219
    My is still working.
    • meraklinetx
      Asus Z97-a power cycle, no boot no cpu voltage
      by meraklinetx
      Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
      05-10-2023, 06:08 AM
    • PantherDave
      by PantherDave
      Hi all!
      05-29-2024, 02:01 PM
      by sam_sam_sam
      03-31-2024, 02:12 PM
    • valvashon
      Samsung UN55FH6030: random power cycling
      by valvashon
      Samsung UN55FH6030, perfect size for my office and does OTA well but isn't a smart TV. That's OK because I am a TV station engineer and only need it for OTA monitoring.
      About a month ago it started power cycling itself once or twice a day and now it's nearly continuous once it's been on for a few minutes. Changing channels would really start it cycling and it would take several minutes to stabilize but now it's just doing it almost non-stop without changing channels.
      Once I disconnected the antenna I found that I could change channels with no issues. My guess is...
      10-20-2023, 09:59 AM
