32LG30-UA with back light, no picture, no sound
  • OldMan
    • Jun 2011
    • 47
    Fixing up this TV for a friend.
    When I got it the TV would turn on for anywhere from 2-4 sec and go right back off. Never could get it to display picture or produce sound. It had no standby voltage so I replaced the power board. This got the TV to come on and stay on but it has no picture or sound. It clearly has back light and no bad lamps. Doesn't respond to remote or power button to turn it off. I can turn off by holding power on TV for roughly 10s or just unplug. Main board gets a steady 12v and interter is getting 24v.
    I'm look to either find a firmware file or get advice to fix whatever anyone might think is wrong still. LG will not release their file to me because there has been no true update, just factory exe.
    Re: 32LG30-UA with back light, no picture, no sound
    Please move the post to TV section, you will get more help there.
    • OldMan
      • Jun 2011
      • 47
      It doesn't look like I can move this thread myself, or else I cannot find the means of doing so. If someone with ability can do it for me that'd be great!
      • OldMan
        • Jun 2011
        • 47
        As I looked into replacing the Main of this TV I noticed a few discrepancies.
        The board in the TV is marked with printing EAX42405502(10) and has a sticker on it with AGF37006901. The TV panel is V315B1-L07 REV C1
        Looking into the parts here are the discrepancies I've found:
        - Assuming the board is actually EAS42405502(10), then this should be for a 47LG50 model and not mine. http://www.shopjimmy.com/lg-ebu42600302-main-board.htm
        - If the sticker was correct, AGF37006901, it should be correct and would match the requirements of the panel. However, part numbers here do not line up when my service code is 32LG30-UA.AUSHLJM http://www.shopjimmy.com/lg-agf37006...for-32lg30.htm
        Should I replace with a true EAX42405502(5) and maybe the set will have video and respond to buttons and remote?
        • OldMan
          • Jun 2011
          • 47
          Just to help anybody else out. I found the mainboard with EAX42405502(10) and a sticker for AGF37006901 as this TV originally had in it. Bought it off ebay and it worked like a charm. TV set is fixed up now, but still wish LG would release firmware to the public to be downloaded and installed from USB to keep all these boards from going to the trashpiles.
          • koby058
            vostro comes up with back light but no picture
            by koby058
            Hi people!!
            The owner said it showed bad picture once in a while (attached)
            I see that there is back light but no picture.
            I want to ask if it is possible to disable the NVIDIA GPU and use the intel one?
            Also attached schematic and BDV
            LINK to schematic & boardview - https://www.badcaps.net/forum/troubl...ll-vostro-5590...
            07-13-2025, 01:03 PM
          • dronerat
            Samsung UE48JU6400W - back light on, sound on, sometimes picture.
            by dronerat
            Hi Guys,
            This forum has been in great help to me, but I stumbled upon a strange problem with a salvaged Samsung TV that I am banging my head to troubleshoot.
            PSU: L48S6 FHS BN44-00807D
            T-Con: BN95-01937A
            Panel: CY-GJ048HGLVLH
            MB: NA (Currently as the TV is assembled and forgot to take picture)
            As I said earlier I have some issues with the TV I got from a friend of mine. The TV had no picture, but sound, back light and everything else was working fine.
            It was sent to an authorized service for repairs and returned with the...
            05-15-2020, 08:03 AM
          • kca
            Samsung UN60F8000BFXZA ~ No Picture or Sound - 5 Res Light Blinks
            by kca
            Hello all ~
            I’m working on this Samsung 60” LED and purchased a new main board a couple of days ago that did not fix the 5 blink issue. The original main board’s HDMI ports (all 4 of them) failed to work and no amount of reflow remedied that.
            This 5 red light blink code on the front panel LED is followed (about 15-20 seconds afterward) by an automatic reboot, and results in 5 more red light blinks. Then the entire cycle repeats itself indefinitely.
            No picture. No sound.
            I tested all the voltages coming out of the power supply...
            10-12-2023, 05:23 PM
            Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
            by sam_sam_sam
            This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
            I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
            I am comparing them to a brand new one that I installed
            The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
            I going to let it run for several days before I remount back on the wall next to the...
            09-05-2024, 06:48 PM
          • slimsoul
            Samsung TV`s UE32J5500AK and UE48H6400AK Red Standby Light - No Picture/Sound
            by slimsoul
            Hi, I'm new here and looking for some advice on how to diagnose an issue i have with 2 samsung TVs.
            I have a UE32J5500AK and a UE48H6400AK both with the same issue of red light but nothing happening on the screen, the red light responds to remote or button press by flashing once but stays red. I have searched forums but most turn up a blinking red light.
            I have tried replaceing the power board on the UE32J5500AK last year but this resulted in the same outcome.
            The UE48H6400AK recently developed some small bright areas on the screen, then last week would not power...
            03-12-2024, 03:55 AM
