Got this tv as a gift. have checked all the fuses, no bulged caps. so started checking voltages, im getting when its on 206v to the Y board, is that right? it has 5v next to the pin I checked. discounected the y board, still nada on the screen, no faint image either. so maybe the problem lies on the main board? im stumped
Samsung 50" Plasma HPT5044, No Picture but powers up
Re: Samsung 50" Plasma HPT5044, No Picture but powers up
You should have used the Search function there is plenty about these models with exact symptoms. In the mean time I will tell you that you likely have at least one blown IC on the upper buffer board which may have in turn killed the YSUS. Is there a steady green light lit on the YSUS ?
Originally posted by dmesser100 View PostHave searched it already, have checked the things mentioned in them. all seemed fine so far.
Alright now we're getting somewhere
It's very unlikely they are all bad but because they of the way they are wired if one is bad they will all appear that way. You need to get them out one at a time and test them. If you find a bad one check the others in circuit to see if they are still shorted or you have removed the short condition.
If you don't have the proper tools to remove the heatsink (requires alot of heat) you can remove the mosfets by removing the screw and lifting upward as there is just enough clearance under the heatsink. You may have to trim the leads a little under the board first and pull the mosfet forward as you pull it up but it can be done this way. Report back.Last edited by mmartell; 08-19-2014, 05:13 PM.
Reporting back! I started removing the 88n30w mosfet one by one, testing what I took out and the remaining ones aon the board as I went. as fate would have it, it was the last one I removed out of the 4 that was bad. could not open and close it like I could the other 3. while im waiting on the replacement to get here, im going back everything else to double check if ive missed some thing else. thanks for the knowledge guys! I will report back when I get the new mosfet.
Originally posted by dmesser100 View PostReporting back! I started removing the 88n30w mosfet one by one, testing what I took out and the remaining ones aon the board as I went. as fate would have it, it was the last one I removed out of the 4 that was bad. could not open and close it like I could the other 3. while im waiting on the replacement to get here, im going back everything else to double check if ive missed some thing else. thanks for the knowledge guys! I will report back when I get the new mosfet.
Can pretty much guarantee it will be shorted.
Getting a new FET is easy for the Ymain, finding a new upper buffer, that's the challenge. If you find a cheap source, let me know. We've got one at work that's had PSU,Y and buffer failure all at once!
